Datasheet Texas Instruments TS5A22364DGSRG4 — Даташит
Серия | TS5A22364 |
Модель | TS5A22364DGSRG4 |
0.65-О© Dual SPDT Analog Switch With Negative Rail Capability 10-VSSOP -40 to 85
TS5A22364 0.65-О© Dual SPDT Analog Switches With Negative Signaling Capability datasheet
PDF, 1.4 Мб, Версия: H, Файл опубликован: 21 июн 2017
Pin | 10 | 10 |
Package Type | DGS | DGS |
Industry STD Term | VSSOP | VSSOP |
JEDEC Code | S-PDSO-G | S-PDSO-G |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | 38R | 38Q |
Width (мм) | 3 | 3 |
Length (мм) | 3 | 3 |
Thickness (мм) | 1.02 | 1.02 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | 1.07 | 1.07 |
Additional Features | Break-before-make,Supports negative voltages,Click/Pop Noise Reduction |
Полоса частот | 18.3 МГц |
Bandwidth(Max) | 18.3 МГц |
Configuration | 2:1 SPDT |
ESD Charged Device Model | 1.5 kV |
ESD HBM | 2.5 kV |
Input/Ouput Voltage(Max) | 5.5 В |
Input/Ouput Voltage(Min) | -3.2 В |
Input/Output Continuous Current(Max) | 350 мА |
Input/Output ON-state Capacitance(Typ) | 370 пФ |
Количество каналов | 2 |
ON-state leakage current(Max) | 0.375 мкА |
Package Group | VSSOP |
Package Size: mm2:W x L | 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Rating | Catalog |
Ron(Max) | 1.3 Ohms |
Ron(Typ) | 0.52 Ohms |
Supply Current(Max) | 5 uA |
Supply Current(Typ) | 0.1 uA |
Supply Range | 5.5 Max |
VIH(Min) | 1.4 В |
VIL(Max) | 0.8 В |
Vdd(Max) | 5.5 В |
Vdd(Min) | 2.3 В |
Vss(Max) | N/A В |
Vss(Min) | N/A В |
- Preventing Excess Power Consumption on Analog SwitchesPDF, 238 Кб, Файл опубликован: 3 июл 2008
Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS5A22364 (4)
- TS5A22364DGSR TS5A22364DGSRG4 TS5A22364DRCR TS5A22364YZPR
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
