Datasheet Texas Instruments TPS54478RTET — Даташит
СерияTPS54478
МодельTPS54478RTET
Входное напряжение от 2,95 В до 6 В, 4 А, синхронный понижающий преобразователь SWIFT™ с ограничением тока сбоя 16-WQFN от -40 до 150
TPS54478 2.95-V to 6-V Input, 4-A Output, 2-MHz, Synchronous Step-Down Switcher With Integrated FETs (SWIFTв„ў) datasheet
PDF, 2.0 Мб, Версия: A, Файл опубликован: 15 ноя 2016
Pin16
Package TypeRTE
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
Маркировка54478
Width (мм)3
Length (мм)3
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Control ModeCurrent Mode
Duty Cycle(Max)98 %
Iout(Max)4 A
Iq(Typ)0.035 мА
Рабочий диапазон температурот -40 до 150 C
Package GroupWQFN
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Power Good,Pre-Bias Start-Up,Synchronous Rectification,Tracking,UVLO Adjustable
Switching Frequency(Max)2000 kHz
Switching Frequency(Min)200 kHz
ТипConverter
Vin(Max)6 В
Vin(Min)2.95 В
Vout(Max)4.5 В
Vout(Min)0.6 В
  • Evaluation Modules & Boards: TPS54478EVM-037
    Evaluation Module for TPS54478 Synchronous Step-Down Converter with Pre-bias Start-Up
  • Minimizing Output Ripple During Startup
    PDF, 675 Кб, Файл опубликован: 22 июн 2017
    A buck DC/DC switching converter has a minimum on-time at which it can operate. This limits theminimum output voltage a converter can regulate to while keeping a fixed frequency. The limitation of theminimum on-time is often only considered for the steady-state output voltage; however, when the outputvoltage ramps up, in most cases the output voltage ramps up from 0 V. When the converter tri
  • Calculating Efficiency
    PDF, 175 Кб, Файл опубликован: 19 фев 2010
    This application report provides a step-by-step procedure for calculating buck converter efficiency and power dissipation at operating points not provided by the data sheet.
  • Understanding Thermal Dissipation and Design of a Heatsink
    PDF, 59 Кб, Файл опубликован: 4 май 2011
    Power dissipation performance must be well understood prior to integrating devices on a printed-circuit board (PCB) to ensure that any given device is operated within its defined temperature limits. When a device is running, it consumes electrical energy that is transformed into heat. Most of the heat is typically generated by switching devices like MOSFETs, ICs, etc. This application report discu
Серия: TPS54478 (2)
На английском языке: Datasheet Texas Instruments TPS54478RTET
