Datasheet Texas Instruments SN74LVC1G17DBVTE4 — Даташит
СерияSN74LVC1G17
МодельSN74LVC1G17DBVTE4
Одиночный буфер триггера Шмитта 5-SOT-23 от -40 до 125
SN74LVC1G17 Single Schmitt-Trigger Buffer datasheet
PDF, 1.7 Мб, Версия: V, Файл опубликован: 23 апр 2014
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаC17F
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeSCHMITT TRIGGER BUFFER
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)24/-24 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Schmitt TriggerYes
Special FeaturesIoff,down translation to Vcc,low power,Schmitt-trigger
Sub-FamilyNon-Inverting Buffer/Driver
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)11,6.5,5.5,5 нс
  • Evaluation Modules & Boards: DLPLCR6500EVM
    DLPВ® LightCrafterВ™ 6500 Evaluation Module
  • Evaluation Modules & Boards: DLPLCR9000EVM
    DLPВ® LightCrafterВ™ 9000 Evaluation Module
  • Evaluation Modules & Boards: DLPLCR4500EVM
    DLPВ® LightCrafterВ™ 4500
  • Designing and Manufacturing with TI's X2SON Packages
    PDF, 134 Кб, Файл опубликован: 23 авг 2017
  • Understanding Schmitt Triggers
    PDF, 80 Кб, Файл опубликован: 21 сен 2011
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G17DBVTE4
