Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TL750L10QLP — Даташит
СерияTL750L10
МодельTL750L10QLP
LDO с одним выходом, 150 мА, фиксированный (10,0 В), низкий ток покоя, защита от сброса нагрузки 60 В 3-TO-92 от -40 до 125
Pin3
Package TypeLP
Industry STD TermTO-92
JEDEC CodeO-PBCY-W
Width (мм)4.3
Length (мм)4.3
Thickness (мм)3.6
Max Height (мм)5.34
Accuracy(%)4
Additional FeaturesOvercurrent Protection
Thermal Shutdown
Approx. Price (US$)0.20 | 1ku
Fixed Output Options(V)10
Iout(Max)(A)0.15
Iq(Typ)(mA)1
Noise(uVrms)700
Operating Temperature Range(C)0 to 125
Output Capacitor TypeCap Free
Non-Ceramic
Output OptionsFixed Output
Package GroupTO-92
Package Size: mm2:W x L (PKG)See datasheet (TO-220)
See datasheet (PDIP)
Powered LoadFPGA
Microcontroller
Microprocessor
Regulated Outputs(#)1
Vdo(Typ)(mV)600
Vin(Max)(V)26
Vin(Min)(V)11
Vout(Max)(V)10
Vout(Min)(V)10
RoHSНе совместим
  • Technical Review of Low Dropout Voltage Regulator Operation And Performance
    PDF, 284 Кб, Файл опубликован: 30 авг 1999
    This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators.
  • Fundamental Theory of PMOS LDO Voltage Regulators
    PDF, 66 Кб, Файл опубликован: 7 май 1999
    This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements.
На английском языке: Datasheet Texas Instruments TL750L10QLP
