Datasheet Texas Instruments 74LVTH16541DLRG4 — Даташит
СерияSN74LVTH16541
Модель74LVTH16541DLRG4
16-битные буферы/драйверы ABT 3,3 В с выходами с 3 состояниями 48-SSOP от -40 до 85
SN54LVTH16541, SN74LVTH16541 datasheet
PDF, 316 Кб, Версия: E, Файл опубликован: 1 ноя 2006
Pin48
Package TypeDL
Industry STD TermSSOP
Width (мм)7.49
Length (мм)15.88
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
Approx. Price (US$)0.82 | 1ku
Bits(#)16
F @ Nom Voltage(Max)(Mhz)160
ICC @ Nom Voltage(Max)(mA)0.005
Operating Temperature Range(C)-40 to 85
Output Drive (IOL/IOH)(Max)(mA)-32/64
Package GroupSSOP
Package Size: mm2:W x L (PKG)48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP)
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)(V)3.6
VCC(Min)(V)2.7
Voltage(Nom)(V)3.3
tpd @ Nom Voltage(Max)(ns)3.5
RoHSНе совместим
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Live Insertion
На английском языке: Datasheet Texas Instruments 74LVTH16541DLRG4
