Datasheet Texas Instruments ADC12D1000CIUT/NOPB — Даташит
СерияADC12D1000
МодельADC12D1000CIUT/NOPB
12-разрядный аналого-цифровой преобразователь (АЦП) с двойным 1,0-GSPS или одинарным 2,0-GSPS 292-BGA от -40 до 85
ADC12D1x00 12-Bit, 2.0/3.2 GSPS Ultra High-Speed ADC datasheet
PDF, 3.6 Мб, Версия: N, Файл опубликован: 31 авг 2015
АЦП азиатских производителей
Pin292
Package TypeNXA
Industry STD TermBGA
JEDEC CodeS-PBGA-N
Package QTY40
CarrierJEDEC TRAY (10+1)
МаркировкаADC12D1000CIUT
Width (мм)27
Length (мм)27
Thickness (мм)2.38
Max Height (мм)2.4
# Input Channels2,1
Analog Input BW2800 МГц
АрхитектураFolding Interpolating
DNL(Max)0.4 +/-LSB
DNL(Typ)0.4 +/-LSB
ENOB9.6 Bits
INL(Max)2.5 +/-LSB
INL(Typ)2.5 +/-LSB
Input BufferYes
Input Range0.8 Vp-p
InterfaceParallel LVDS
Package GroupBGA
Package Size: mm2:W x L292BGA: 729 mm2: 27 x 27(BGA) PKG
Power Consumption(Typ)3380 mW
Reference ModeInt
Разрешение12 Bits
SFDR71 дБ
SINAD59.7 дБ
SNR60.2 дБ
Sample Rate(Max)1000,2000 MSPS
  • Evaluation Modules & Boards: ADC12D1600RB
    12-Bit, Dual 1.6/1.8 GSPS or Single 3.2/3.6 GSPS A/D Converter Reference Board
  • From Sample Instant to Data Output: Understanding Latency in the GSPS ADC
    PDF, 392 Кб, Файл опубликован: 18 дек 2012
    For many applications which use ultra high-speed ADCs, latency can be a critical performance specification. For example, if the ADC is used in any kind of feedback loop, then the absolute latency is an important factor. For a MIMO system such as a phased array radar, the relative difference and variability in latency becomes important. This application note covers latency in the GSPS ADC products,
  • Maximizing SFDR Performance in the GSPS ADC: Spur Sources and Methods of Mitigat
    PDF, 720 Кб, Файл опубликован: 9 дек 2013
    The SFDR performance of an ADC is limited by the largest spur in the spectrum from DC to Fs / 2. These spurs can either be reduced or avoided entirely for maximum SFDR performance, based on the application. This reference design explores the reason behind spurs in the 10-bit and 12-bit GSPS ADCfamily. The specific products covered are: ADC12D1800RF, ADC12D1600RF, ADC12D1000RF, ADC12D800RF, ADC12
  • AN-2128 ADC1xD1x00 Pin Compatibility (Rev. C)
    PDF, 60 Кб, Версия: C, Файл опубликован: 1 май 2013
    In order to facilitate upgrading applications from a 10-bit Gig ADC to a 12-bit Gig ADC, the ADC10D1x00(ADC10D1500/ADC10D1000) is designed to be pin-compatible with the ADC12D1x00(ADC12D1800/1600/1000). This means that a single board layout may be designed with both resolutionADCs in mind for more cost efficient and time-to-market product development.
  • AN-2177 Using the LMH6554 as a ADC Driver (Rev. A)
    PDF, 1.7 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses the use of the Texas Instruments LMH6554 as an ADC driver.
  • AN-2132 Synchronizing Multiple GSPS ADCs in a System: The AutoSync Feature (Rev. G)
    PDF, 169 Кб, Версия: G, Файл опубликован: 3 фев 2017
Серия: ADC12D1000 (2)
  • Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > High Speed ADCs (>10MSPS)
На английском языке: Datasheet Texas Instruments ADC12D1000CIUT/NOPB
