Datasheet Texas Instruments OPA2735AIDR — Даташит
Серия | OPA2735 |
Модель | OPA2735AIDR |
0,05 мкВ/градус Цельсия (макс.) КМОП-операционный усилитель с однополярным питанием, серия с нулевым дрейфом, 8-SOIC от -40 до 85
0.05µV/°C max, Single-Supply CMOS Operational Amplifier Zero-Drift datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 21 фев 2005
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | OPA | 2735A |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Additional Features | Zero Drift |
Архитектура | CMOS |
CMRR(Min) | 115 дБ |
CMRR(Typ) | 130 дБ |
GBW(Typ) | 1.6 МГц |
Input Bias Current(Max) | 200 pA |
Iq per channel(Max) | 0.75 мА |
Iq per channel(Typ) | 0.6 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 0.01 uV/C |
Output Current(Typ) | 20 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Catalog |
Slew Rate(Typ) | 1.5 V/us |
Total Supply Voltage(Max) | 12 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 135 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.005 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2735 (7)
