Datasheet Texas Instruments MSP430FG6426IPZR — Даташит
СерияMSP430FG6426
МодельMSP430FG6426IPZR
MSP430FG642x Микроконтроллер смешанных сигналов 100-LQFP от -40 до 85
MSP430FG662x, MSP430FG642x Mixed-SignalMicrocontrollers datasheet
PDF, 3.2 Мб, Файл опубликован: 22 май 2015
Pin100
Package TypePZ
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаFG6426
Width (мм)14
Length (мм)14
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
ADCSigmaDelta16 - 10ch
AESN/A
Active Power250 uA/MHz
Additional FeaturesOpAmp,DAC,LCD,Real-Time Clock,Temp Sensor,Brown Out Reset
BSLUART
CPUMSP430
Comparators12
DMA6
Featuredf6
Тактовая частота20 МГц
GPIO Pins73
I2C2
Max VCC3.6
Min VCC1.8
Multiplier32x32
Non-volatile Memory128 KB
Package GroupLQFP
Package Size: mm2:W x L100LQFP: 256 mm2: 16 x 16(LQFP) PKG
RAM10 KB
SPI4
Special I/ON/A
Standby Power3.4 LPM3-uA
Timers - 16-bit4
UART2
Wakeup Time3 us
  • Evaluation Modules & Boards: MSP-TS430PZ100AUSB
    MSP-TS430PZ100AUSB - 100-pin Target Development Board for MSP430FG6x MCUs
  • Evaluation Modules & Boards: MSP-FET430U100AUSB
    100-pin Target Development Board and MSP-FET Bundle - MSP430FG6x MCUs-Microcontrollers not included
  • Using the MSP430 RTC_B Module With Battery Backup Supply (Rev. B)
    PDF, 135 Кб, Версия: B, Файл опубликован: 4 июн 2015
    Some applications need to retain an accurate real-time clock (RTC) through battery changes, power outages, and other events. For these applications, MSP430в„ў devices that contain the RTC_B Real-Time Clock module with a Battery Backup System can be a great fit. This application note demonstrates how to use RTC_B with Battery Backup Supply functionality to retain the time and keep the RTC counting th
  • Designing With MSP430 and Segment LCDs (Rev. A)
    PDF, 2.1 Мб, Версия: A, Файл опубликован: 20 июл 2015
    Segment liquid crystal displays (LCDs) are needed to provide information to users in a wide variety of applications from smart meters to electronic shelf labels (ESL) to medical equipment. Several MSP430в„ў microcontroller families include built-in low-power LCD driver circuitry that allows the MSP430 MCU to directly control the segmented LCD glass. This application note helps explain how segmented
  • Advanced Debugging Using the Enhanced Emulation Module (EEM) With CCS v6 (Rev. F)
    PDF, 837 Кб, Версия: F, Файл опубликован: 6 сен 2016
Серия: MSP430FG6426 (2)
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430F5x/6x
На английском языке: Datasheet Texas Instruments MSP430FG6426IPZR
