Datasheet Texas Instruments UCC3583DTRG4 — Даташит
СерияUCC3583
МодельUCC3583DTRG4
Режим переключения вторичного пост-регулятора 14-SOIC от 0 до 70
Switch Mode Secondary Side Post Regulator datasheet
PDF, 1.3 Мб, Версия: B, Файл опубликован: 18 янв 2005
Pin14
Package TypeD
Package QTY2500
МаркировкаUCC3583D
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Control MethodCurrent
Duty Cycle(Max)95 %
Frequency(Max)500 kHz
Gate Drive(Typ)1.5 A
Special FeaturesError Amplifier,Post Regulation,Soft Start,Synchronization Pin
TopologySecondary Side Regulator
UVLO Thresholds On/Off9/8.4 В
Vin(Max)15 В
Vin(Min)9 В
  • DN-83 UC3584DW Secondary Side Post Regulator EVM Board Schematic
    PDF, 38 Кб, Файл опубликован: 5 сен 1999
    This design note describes an evaluation board for the UC3584 Secondary Side Post Regulator. The board contains a fully functional auxiliary converter. This controller provides a semiconductor solution for regulating auxiliary outputs in transformer isolated power supplies where magnetic amplifiers (magamps) were previously used. A schematic and list of materials are provided.
  • A Power Management Solution for Efficient, Multiple Output Applications
    PDF, 293 Кб, Файл опубликован: 4 окт 2001
Серия: UCC3583 (3)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UCC3583DTRG4
