Datasheet Texas Instruments UCC25600DRG4 — Даташит
СерияUCC25600
МодельUCC25600DRG4
8-контактный высокопроизводительный контроллер LLC с резонансным режимом 8-SOIC от -40 до 125
UCC25600 8-Pin High-Performance Resonant Mode Controller datasheet
PDF, 3.6 Мб, Версия: C, Файл опубликован: 2 июл 2015
Package TypeD
Package QTY2500
Маркировка25600
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Control MethodVoltage
Duty Cycle(Max)50 %
Frequency(Max)350 kHz
Frequency(Min)40 kHz
Gate Drive(Typ)0.8 A
TopologyHalf-Bridge,Resonant LLC
Vin(Max)410 В
Vin(Min)370 В
  • Evaluation Modules & Boards: UCC25600EVM
    LLC Resonant Half-Bridge Converter 300-W Evaluation Module
  • Analysis and Measurement of Resonant Tank Current on LLC
    PDF, 970 Кб, Файл опубликован: 30 июл 2013
  • Feedback Loop Design of an LLC Resonant Power Converter (Rev. A)
    PDF, 167 Кб, Версия: A, Файл опубликован: 24 ноя 2010
    This application note describes an approach to design feedback loop compensation for an LLC resonant half-bridge power converter. The approach described here is based on the measured Bode plots of the modulator generated by a network analyzer. Frequency domain poles and zeros in the feedback loop compensation can be analytically determined, then fine-tuned with a bench test. This measurement is ne
  • High-Efficiency AC-DC TV Power Solutions: An Intelligent LED Backlight Scheme
    PDF, 758 Кб, Файл опубликован: 15 июл 2011
    This application note presents novel power architectures with regard to the ac-dc total power supply for anLCD TV design, achieving higher power efficiencies and lower cost. The revolutionary iHVMв„ў mechanism enables intelligent LED bias control to minimize power loss. On the other hand, the fast LED drivers provide precise LED ON-OFF control. In this report, two reference designs are discussed.
  • A 300-W, Universal Input, Isolated PFC Power Supply for LCD TV Applications (Rev. B)
    PDF, 858 Кб, Версия: B, Файл опубликован: 19 мар 2009
Серия: UCC25600 (3)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UCC25600DRG4
