Datasheet Texas Instruments LM1770TMF/NOPB — Даташит
СерияLM1770
МодельLM1770TMF/NOPB
Низковольтный синхронный понижающий контроллер SOT23 без внешней компенсации 5-SOT-23 от -40 до 125
LM1770 Low-V SOT23 Synch Buck Cntrr w/No Ext Compensation datasheet
PDF, 862 Кб, Версия: C, Файл опубликован: 3 апр 2013
IC REG CTRLR BUCK SOT23-5. Buck Regulator Positive Output Step-Down DC-DC Controller IC SOT-23-5. PMIC - Voltage Regulators - DC DC...
LM1770TMF/NOPB
51 ₽
LM1770TMF/NOPB
93 ₽
LM1770TMF/NOPB
93 ₽
LM1770TMF/NOPB
147 ₽
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY1000
МаркировкаSKKB
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Control ModeConstant on-time (COT)
Duty Cycle(Max)98 %
Iout(Max)4 A
Iq(Typ)0.4 мА
Number of Phases1
Package GroupSOT-23
Regulated Outputs1
Special FeaturesLight Load Efficiency
Switching Frequency(Max)2000 kHz
Switching Frequency(Min)500 kHz
ТипController
Vin(Max)5.5 В
Vin(Min)2.8 В
Vout(Max)4.5 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: LM1770EVAL
    Low-Voltage SOT23 Synchronous Buck Controller With No External Compensation
  • AN-1414 LM1770 Design Reference (Rev. A)
    PDF, 226 Кб, Версия: A, Файл опубликован: 23 апр 2013
    This application report presents several reference designs that can be used to implement the TexasInstruments LM1770 Synchronous Buck Controller in a wide variety of configurations.
  • Advanced Topics in Powering FPGAs
    PDF, 645 Кб, Файл опубликован: 22 мар 2007
  • Controlling Output Ripple & Achiev ESR Indep Constant On-Time Reg Designs (Rev. A)
    PDF, 178 Кб, Версия: A, Файл опубликован: 23 апр 2013
    Of all the voltage regulator control strategies ever devised, the hysteretic regulator is probably about thesimplest. This control methodology simply turns a switch on when the output voltage is below a referenceand turns the switch off when the output rises to a slightly higher reference. The output ripple is thereforea direct function of the difference between the upper and lower reference
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments LM1770TMF/NOPB
