Datasheet Texas Instruments TPS62230DRYR — Даташит
СерияTPS62230
МодельTPS62230DRYR
Сверхкомпактный понижающий преобразователь 2 МГц с DCS-управлением в корпусе 1x1,5 SON 6-SON от -40 до 125
TPS6223xx 2-MHz and 3-MHz Ultra Small Step-Down Converter in 1 x 1.5 USON Package datasheet
PDF, 2.1 Мб, Версия: G, Файл опубликован: 21 янв 2016
Pin6
Package TypeDRY
Industry STD TermUSON
JEDEC CodeR-PDSO-N
Package QTY5000
МаркировкаGV
Width (мм)1
Length (мм)1.45
Thickness (мм).5
Pitch (мм).5
Max Height (мм).6
Control ModeConstant on-time (COT)
Duty Cycle(Max)100 %
Iout(Max)0.5 A
Iq(Typ)0.022 мА
Package GroupSON
Regulated Outputs1
Special FeaturesEnable,Light Load Efficiency,Synchronous Rectification
Switching Frequency(Max)3000 kHz
Switching Frequency(Min)2000 kHz
ТипConverter
Vin(Max)6 В
Vin(Min)2.05 В
Vout(Max)2.5 В
Vout(Min)2.5 В
  • Evaluation Modules & Boards: TPS622312EVM-574
    Evaluation Module for TPS622312, TPS622313, TPS622314 Ultra Small Step Down Converter (1.3, 1.5, 2)V
  • Evaluation Modules & Boards: TPS62239EVM-574
    Ultra Small Step Down Converter for TPS622311, TPS62235, TPS62239, Evaluation Module
  • Evaluation Modules & Boards: TPS62230EVM-574
    Evaluation Module for TPS62230, TPS62231, TPS62232 Ultra Small Step Down Converter 1.2V, 1.8V, 2.5V
  • Evaluation Modules & Boards: TPS622315EVM-574
    Evaluation Module for TPS622315, TPS622316, TPS622317 Ultra Small Step Down Conv. (1.15, 2.7, 2.9)V
  • Evaluation Modules & Boards: TPS62233EVM-574
    Evaluation Module for TPS62233, TPS622310, TPS62237 Ultra Small Step Down Converter (2.3, 3.0, 3.3)V
  • Evaluation Modules & Boards: TPS62236EVM-574
    Evaluation Module for TPS62234, TPS62238, TPS62236 Ultra Small Step Down Conv. (1.85, 2.1, 2.25)V
  • Evaluation Modules & Boards: TPS62230EVM-370
  • Evaluation Modules & Boards: EVM430-FR6989
    Water meter reference design - Extented Scan Interface (ESI) enabled, ultra-low power MSP430FR6989
  • High-Vin, High-Efficiency Power Solution Using DC/DC Converter for the DM365
    PDF, 165 Кб, Файл опубликован: 4 авг 2009
    TMS320DM365,TPS62111,TPS62290,TPS62231 High-Vin, High-Efficiency Power Solution Using DC/DC Converter for TMS320DM365
  • High-Efficiency Power Solution Using DC/DC Converter for the DM365 (Rev. A)
    PDF, 151 Кб, Версия: A, Файл опубликован: 11 сен 2009
  • How to Measure the Control Loop of DCS-Control Devices (Rev. A)
    PDF, 259 Кб, Версия: A, Файл опубликован: 9 авг 2012
  • High-efficiency low-ripple DCS-Control offers seamless PWM/pwr-save transitions
    PDF, 605 Кб, Файл опубликован: 25 июл 2013
  • Understanding frequency variation in the DCS-Control(TM) topology
    PDF, 224 Кб, Файл опубликован: 30 окт 2015
  • Five steps to a great PCB layout for a step-down converter
    PDF, 162 Кб, Файл опубликован: 29 янв 2015
  • Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)
    PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
  • Testing tips for applying external power to supply outputs without an input volt
    PDF, 110 Кб, Файл опубликован: 24 окт 2016
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
На английском языке: Datasheet Texas Instruments TPS62230DRYR
