Datasheet Texas Instruments VFC320CP — Даташит
СерияVFC320
МодельVFC320CP
Преобразователь напряжение-частота и частота-напряжение с погрешностью линейности 0,1% при частоте 1 МГц 14-PDIP от -25 до 85
VFC320: Voltage-to-Frequency and Frequency-to-Voltage Converter datasheet
PDF, 228 Кб, Версия: A, Файл опубликован: 13 авг 2001
Pin14
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаVFC320CP
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Approx. price15.82 | 1ku US$
Operating temperature range-25 to 85 C
Package GroupPDIP|14
Package size: mm2:W x L14PDIP: 181 mm2: 9.4 x 19.3 (PDIP|14) PKG
Vs(Max)20 В
Vs(Min)13 В
  • Frequency-To-Voltage Conversion
    PDF, 106 Кб, Файл опубликован: 27 сен 2000
    This bulletin describes three techniques for making a precision FVC using a VFC. The standard technique has high precision but high ripple or slow settling. Adding an output filter can improve the settling-time ripple trade-off but adds error. A third new technique can eliminate ripple from the FVC output and improve settling time by more than 1000/1 as compared to the conventional FVC. Moreove
  • Voltage-to-Frequency Converters Offer Useful Options in A/D Conversion
    PDF, 48 Кб, Файл опубликован: 2 окт 2000
    Voltage-to-frequency converters (VFCs) provide unique characteristics when used as analog-to-digital (A/D) converters. Their excellent accuracy linearity and integrating input characteristics often provide performance attributes unattainable with other converter types. By using efficient frequency counting techniques familiar speed/accuracy tradeoffs can be averted.
  • Semiconductors > Analog and Mixed-Signal > Amplifiers > Special function amplifiers > Frequency converters
На английском языке: Datasheet Texas Instruments VFC320CP
