Datasheet Texas Instruments LM77CIMMX-5/NOPB — Даташит
СерияLM77
МодельLM77CIMMX-5/NOPB
В±1.5В°C Temperature Sensor with Alert Function and I2C/SMBus Interface 8-VSSOP -55 to 125
9Bit + Dig Temp Sens & Thermal Window Comparator w/Two-Wire Interface datasheet
PDF, 1.4 Мб, Версия: F, Файл опубликован: 22 мар 2013
Package TypeDGK
Industry STD TermVSSOP
Package QTY3500
МаркировкаT07C
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Addresses4
Approx. Price (US$)0.90 | 1ku
InterfaceI2C
SMBus
2-Wire
Iq(Typ)(uA)250
Local Sensor Accuracy(Max)(+/- C)1.5
Operating Temperature Range(C)-55 to 125
Package GroupVSSOP
Package Size: mm2:W x L (PKG)8VSSOP: 15 mm2: 4.9 x 3(VSSOP)
Special FeaturesFault Queue
Supply Current(Max)(uA)500
Supply Current(Typ)(uA)250
Supply Voltage(Max)(V)5.5
Supply Voltage(Min)(V)3
Temp Resolution(Max)(bits)10
  • Applying I2C-Compatible Temperature Sensors in Systems With Slow Clock Edges (Rev. A)
    PDF, 33 Кб, Версия: A, Файл опубликован: 6 май 2013
    This Application Note describes a method of interfacing a given microcontroller with a Texas Instruments digital temperature sensor.
  • Sensing and Monitoring for Control and Protection Seminar
    PDF, 245 Кб, Файл опубликован: 17 фев 2003
  • Semiconductors > Sensing Products > Temperature Sensors > Local Digital Temperature Sensors
LM77CIMMX5/NOPB, LM77CIMMX 5/NOPB
На английском языке: Datasheet Texas Instruments LM77CIMMX-5/NOPB
