Datasheet Texas Instruments TMS320C6474FCUN — Даташит
СерияTMS320C6474
МодельTMS320C6474FCUN
Многоядерный процессор цифровых сигналов 561-FC/CSP от 0 до 85
TMS320C6474 Multicore Digital Signal Processor Data Manual datasheet
PDF, 1.8 Мб, Версия: H, Файл опубликован: 11 апр 2011
Pin561561
Package TypeCUNCUN
Package QTY6060
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаTMS320C6474CUN@2006 TI
Width (мм)2323
Length (мм)2323
Thickness (мм)2.652.65
DSP3 C64x+
  • Development Kits: TMDSEVM6472
    TMS320C6472 Evaluation Module
    XDS200 USB Debug Probe
  • TMS320C6474 Multicore Digital Signal Processor Technical Brief
    PDF, 288 Кб, Файл опубликован: 14 окт 2008
    The TMS320C6474 DSP integrates three 1-GHz C64x+ DSP CPU cores, a host of high-speed peripherals, and large amounts of internal memory in a compact 23 mm by 23 mm package. These features allow the C6474 device to provide significant performance integration and high-performance density, along with substantial efficiencies in power, cost, and board space.
  • TMS320C6474 Power Consumption Summary
    PDF, 85 Кб, Файл опубликован: 14 окт 2008
    This document discusses the power consumption of the Texas Instruments TMS320C6474 digital signal processor (DSP). The power consumption on the TMS320C6474 device is highly application-dependent; therefore, a power spreadsheet that estimates power consumption is provided along with this application report. This spreadsheet can be used to model power consumption for user applications such as power
  • TMS320C6474 Module Throughput Application Report
    PDF, 140 Кб, Файл опубликован: 14 окт 2008
    This document provides information on the C6474 module throughput.
  • Direct I/O Library
    PDF, 30 Кб, Файл опубликован: 28 авг 2009
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://www.tiexpressdsp.com/index.php/DIO_LibraryThis DIO library aims at providing a CSL-like Serial RapidIO (SRIO) functional layer for the directIO mode of Texas Instruments' TMS320C64
  • TMS320C6474 SERDES Implementation Guidelines
    PDF, 127 Кб, Файл опубликован: 14 окт 2008
    This document contains implementation instructions for the three serializer/deserializer (SERDES) based interfaces on the TMS320C6474 DSP device. These include the Serial RapidIOВ® (SRIO), antenna, and serial gigabit media independent interface (SGMII) interfaces.Serial RapidIO is an industry-standard high-speed switched-packet interconnect. The antenna interface is compatible with two industr
  • TMS320C6474 Hardware Design Guide (Rev. B)
    PDF, 381 Кб, Версия: B, Файл опубликован: 3 авг 2010
    This document describes hardware system design considerations for the TMS320C6474 device.
  • Connecting Antenna Interface (AIF) With TDM Bridge Chip (IDT 80HFC001)
    PDF, 28 Кб, Файл опубликован: 28 авг 2009
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://tiexpressdsp.com/index.php/AIFThis article was designed for both beginners and advanced users of the Antenna Interface in the embedded processor TMS320C6474 chip support software library. It i
  • TMS320C6474 DDR2 Implementation Guidelines (Rev. A)
    PDF, 96 Кб, Версия: A, Файл опубликован: 4 авг 2009
    This document provides implementation instructions for the DDR2 interface contained on the C6474 DSP device.
  • Inter-Core Communication on TMS320C6474
    PDF, 961 Кб, Файл опубликован: 12 янв 2009
    Inter-core (also called Inter-CPU or Inter-Processor) communication on the C6474 multi-core DSP devices can be accomplished using the on-chip inter-processor communication (IPC) module. The main function of the IPC module is to provide inter-core interrupts. Optionally, flags can be sent along with an interrupt for implementation or more advanced inter-core communication protocols.The purpose o
  • Using the TMS320C6474 Antenna Interface (AIF) for Inter-DSP Communication
    PDF, 27 Кб, Файл опубликован: 28 авг 2009
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:href=http://wiki.davincidsp.com/index.php/AIF_Inter_DSP_CommunicationThe TMS320C6474 Antenna Interface (AIF) is a CPRI and OBSAI-compliant peripheral whose primary purpose
  • TMS320C6474 Common Bus Architecture (CBA) Throughput
    PDF, 73 Кб, Файл опубликован: 14 окт 2008
    This application report presents common bus architecture protocols and components as main factors for generic throughput analysis. It provides necessary details on the internal bus structure which enables you to estimate system-on-chip (SoC) performance for a given application.
  • How to Approach Inter-Core Communication on TMS320C6474
    PDF, 142 Кб, Файл опубликован: 27 янв 2009
    Today's digital signal processor (DSP) architectures are confronted with the tough requirement of addressing a wide-range of standards and meeting a cost-effective performance/power trade-off. Increasing raw million instructions per second (MIPS) performance just by running at a higher frequency is not possible anymore since leakage is becoming a dominant factor with shrinking silicon geometries.
  • TPS40197 Reference Design
    PDF, 614 Кб, Файл опубликован: 17 дек 2008
    The TPS40197 reference design is a synchronous buck converter providing VID programmable output voltage from 0.9 V to 1.2 V at up to 7 A from a 12-V or 5-V bus (4.75 V ~ 13.2 V). The design uses the TPS40197 – a synchronous buck controller with 4-bit VID interface for Smart-Reflex™ DSPs.
  • C6474 (x2) Power Using Modules
    PDF, 107 Кб, Файл опубликован: 30 сен 2008
  • C6474 (x4) Power Using Modules
    PDF, 131 Кб, Файл опубликован: 1 окт 2008
  • TMS320C6455 to TMS320C6474 Migration Guide
    PDF, 311 Кб, Файл опубликован: 14 окт 2008
    The TMS320C6455 fixed-point digital signal processor (DSP) and the TMS320C6474 communications infrastructure DSP are two of Texas Instruments’ high-performance DSP processors, each offering high-speed DSP processing, large internal memories, a rich set of peripherals, and other support functions useful in a system environment.This application report describes device considerations for migrati
  • Tuning VCP2 and TCP2 Bit Error Rate Performance
    PDF, 293 Кб, Файл опубликован: 11 фев 2011
    In most customer applications, a high level of decoding bit error rate (BER) performance is required. Since Convolutional codes and Turbo codes are widely used in wireless communication systems, TI DSPs integrate two high-performance embedded coprocessors (enhanced Viterbi decoder coprocessor and enhanced Turbo decoder coprocessor) that significantly speed up channel-decoding operations on-chip.
  • Error Detection and Correction Mechanism of TMS320C64x+/C674x (Rev. A)
    PDF, 80 Кб, Версия: A, Файл опубликован: 19 июл 2013
    This application report describes the error detection and correction mechanism of the C64x+/C674x megamodule L1P and L2 memories implemented on some devices. Depending on the type of application, these mechanisms are used to either provide diagnostic measures to detect faults in the memory that could lead to unacceptable risk for the user or to increase the availability of the system.
  • Multicore Programming Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 29 авг 2012
    As application complexity continues to grow, we have reached a limit on increasing performance by merely scaling clock speed. To meet the ever-increasing processing demand, modern System-On-Chip solutions contain multiple processing cores. The dilemma is how to map applications to multicore devices. In this paper, we present a programming methodology for converting applications to run on multicore
  • EDMA v2.0 to EDMA v3.0 (EDMA3) Migration Guide (Rev. A)
    PDF, 292 Кб, Версия: A, Файл опубликован: 21 авг 2008
    This application report summarizes the key differences between the enhanced direct memory access (EDMA3) used on C64x+в„ў DSP devices and the EDMA2 used on TMS320C64xв„ў DSP devices, and provides guidance for migrating from EDMA2 to EDMA3.
  • TMS320C64x to TMS320C64x+ CPU Migration Guide (Rev. A)
    PDF, 310 Кб, Версия: A, Файл опубликован: 20 окт 2005
    This document describes migration from the Texas Instruments TMS320C64xв„ў digital signal processor (DSP) to the TMS320C64x+в„ў DSP. The objective of this document is to indicate differences between the two cores and to briefly describe new features. Functionality in the devices that is identical is not included. For detailed information about either device, see the TMS320C64x/C64x+ DSP
  • Semiconductors > Processors > Digital Signal Processors > C6000 DSP > Other C6000 DSP
На английском языке: Datasheet Texas Instruments TMS320C6474FCUN
