Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPS62352DRCR — Даташит
СерияTPS62352
МодельTPS62352DRCR
Понижающий преобразователь 1 А, 3 МГц с I2C для динамического масштабирования напряжения 10-VSON от -40 до 85
800-mA 3-MHz Synchronous Step-Down Converter With I2C(TM) Compatible Interface datasheet
PDF, 1.6 Мб, Версия: E, Файл опубликован: 15 апр 2008
Pin10
Package TypeDRC
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Approx. Price (US$)0.69 | 1ku
Control ModeVoltage Mode
Duty Cycle(Max)(%)80
Iout(Max)(A)0.8
Iq(Typ)(mA)0.028
Operating Temperature Range(C)-40 to 85
Package GroupVSON
Regulated Outputs(#)1
Special FeaturesDynamic Voltage Scaling
Enable
Frequency Synchronization
Light Load Efficiency
Output Discharge
Synchronous Rectification
Switching Frequency(Max)(kHz)3350
Switching Frequency(Min)(kHz)2650
ТипConverter
Vin(Max)(V)5.5
Vin(Min)(V)2.7
Vout(Max)(V)1.4375
Vout(Min)(V)0.75
RoHSНе совместим
  • Using The TPS6235x Without The I2C Interface
    PDF, 69 Кб, Файл опубликован: 17 май 2007
    The TPS6235x series of DC/DC converters have an I2C-compatible interface that facilitates changing the output voltage for dynamic voltage-scaling applications. However, it is possible to use the TPS6235x series of converters, without the I2C interface, as a standalone DC/DC converter that can be dynamically switched between two fixed voltages. This technique does not work for the TPS62351.
  • Powering OMAP3 With TPS6235x: Design-In Guide
    PDF, 296 Кб, Файл опубликован: 3 дек 2008
    The OMAP35xx Applications Processors have a diverse set of power management features which potentially enable lower cost power solutions based on your application. This design-in guide describes a power solution based on the TPS6235x device. This guide can be used to evaluate this solution for your design or help you make decisions when designing in this solution.
  • Five steps to a great PCB layout for a step-down converter
    PDF, 162 Кб, Файл опубликован: 29 янв 2015
  • Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)
    PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
  • Testing tips for applying external power to supply outputs without an input volt
    PDF, 110 Кб, Файл опубликован: 24 окт 2016
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
Серия: TPS62352 (3)
На английском языке: Datasheet Texas Instruments TPS62352DRCR
