Datasheet Texas Instruments LM3S1G21-IQC80-A2 — Даташит
СерияLM3S1G21
МодельLM3S1G21-IQC80-A2
Микроконтроллер Stellaris LM3S 100-LQFP от -40 до 85
Stellaris LM3S1G21 Microcontroller Data Sheet datasheet
PDF, 5.8 Мб, Версия: C, Файл опубликован: 3 июл 2014
IC MCU 32BIT 384KB FLASH 100LQFP. ARM® Cortex®-M3 Stellaris® ARM® Cortex®-M3S 1000 Microcontroller IC 32-Bit 80MHz 384KB (384K x 8) FLASH...
LM3S1G21-IQC80-A2T
65 ₽
Hi-Tech Circuit Group
LM3S1G21-IQC80-A2
Рутоника
LM3S1G21-IQC80-A2
LM3S1G21-IQC80-A2
Pin100100
Package TypePZPZ
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
МаркировкаLM3S1G21IQC80
Width (мм)1414
Length (мм)1414
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
RoHSНе совместим
  • Configuring StellarisВ® Tempest- and Firestorm-Class and MCUs W/ Pin Multiplexing (Rev. C)
    PDF, 172 Кб, Версия: C, Файл опубликован: 6 ноя 2013
    Many members of the StellarisВ® family of microcontrollers provide system designers with a great deal of control over the placement and selection of peripheral module signals that are alternate functions for GPIO signals. This application note provides an overview of the pin muxing implementation, an explanation of how a system designer defines a pin configuration, and examples of the pin confi
LM3S1G21IQC80A2, LM3S1G21 IQC80 A2
На английском языке: Datasheet Texas Instruments LM3S1G21-IQC80-A2
