Datasheet Texas Instruments LMR62421XMFE/NOPB — Даташит
СерияLMR62421
МодельLMR62421XMFE/NOPB
ПРОСТОЙ ПЕРЕКЛЮЧАТЕЛЬ 2,7–5,5 В, повышающий стабилизатор 2,1 А в SOT-23 5-SOT-23 от -40 до 125
LMR62421 SIMPLE SWITCHER ® 24Vout, 2.1A Step-Up Voltage Regulator in SOT-23 datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 4 апр 2013
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаSH8B
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Duty Cycle(Max)96 %
Iq(Typ)7 мА
Package GroupSOT-23
Regulated Outputs1
Special FeaturesEnable
Switch Current Limit(Min)2.1 A
Switch Current Limit(Typ)3 A
Switching Frequency(Max)1600 kHz
Switching Frequency(Min)1600 kHz
ТипConverter
Vin(Max)5.5 В
Vin(Min)2.7 В
Vout(Max)24 В
Vout(Min)3 В
  • Evaluation Modules & Boards: LMR62421XSDDEMO
    LMR62421 SIMPLE SWITCHERВ® 24Vout, 2.1A Small Step-Up Regulator Demo Board
  • Development Kits: LAUNCHXL-F28379D
    C2000 Delfino MCUs F28379D LaunchPad Development Kit
  • Softstart Using Constant Current Constant Voltage Approach
    PDF, 337 Кб, Файл опубликован: 24 июл 2015
    In many systems backup power is provided either by batteries or simply by a large value capacitor. Inthese applications the capacitor would only provide the current when the primary power source fails.Further, these applications are usually for light load currents. During normal operation the backupcapacitors are kept charged up by a DC/DC converter. The challenge involved in an application
  • Working With Boost Converters
    PDF, 159 Кб, Файл опубликован: 15 июн 2015
    This brief note highlights some of the more common pitfalls when using boost regulators. These includemaximum achievable output current and voltage, short circuit behavior and basic layout issues. It isassumed that the reader is familiar with the basic operation of a boost regulator.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • Inverted SEPIC Made SIMPLE
    PDF, 408 Кб, Файл опубликован: 31 июл 2015
    There can be quite a few applications that require a conversion from a negative input voltage to a negativeoutput voltage and there are a few ways to go about doing it. The telecom industry is one such examplewhere the rails are usually negative. This design space along with being limited is not well explored. In thisapplication note we will go over the use of an integrated boost regulator i
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments LMR62421XMFE/NOPB
