Заказные клавиатуры Accord по вашему ТЗ
Datasheet ТI TLV1578CDAR — Даташит
СерияTLV1578
МодельTLV1578CDAR
Datasheet Texas Instruments TLV1578CDAR
8-гл.
2.7 V to 5.5 V, 1-/-8 Channel 10-Bit Parallel Analog-to-Digital Converters datasheet
PDF, 627 Кб, Версия: D, Файл опубликован: 11 июл 2000
10-битный АЦП, 1,25 MSPS, 8-канальный, DSP/SPI, аппаратно настраиваемый, малое энергопотребление 32-TSSOP от 0 до 70
  • Interfacing the TLV1571/78 Analog-to-Digital Converter to the TMS320C542 DSP
    PDF, 192 Кб, Файл опубликован: 7 окт 1999
    This application report presents a hardware solution for interfacing the TLV1571/TLV1578 10-bit, 1.25 MSPS low-power analog-to-digital converter (ADC) to the 16-bit fixed-point TMS320C542 digital signal processor (DSP). The report describes the interface hardware and C-callable software routines, which support communication between ADC and DSP.
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
На английском языке: Datasheet Texas Instruments TLV1578CDAR
Политика конфиденциальности
