Datasheet Texas Instruments SN74LVCH16652ADLG4 — Даташит
СерияSN74LVCH16652A
МодельSN74LVCH16652ADLG4
16-битный шинный приемопередатчик и регистр с выходами с 3 состояниями 56-SSOP от -40 до 125
SN74LVCH16652A 16-Bit Bus Transceiver and Register with 3-State Outputs datasheet
PDF, 1.1 Мб, Версия: J, Файл опубликован: 27 дек 2014
Pin56
Package TypeDL
Industry STD TermSSOP
Package QTY20
МаркировкаLVCH16652A
Width (мм)7.49
Length (мм)18.41
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
Bits16
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.02 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupSSOP
Package Size: mm2:W x L56SSOP: 191 mm2: 10.35 x 18.42(SSOP) PKG
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)6.4,6.3 нс
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Registered Transceiver
На английском языке: Datasheet Texas Instruments SN74LVCH16652ADLG4
