Datasheet Texas Instruments TPS780300250DRVR — Даташит
Серия | TPS780 |
Модель | TPS780300250DRVR |
150 мА, LDO-регулятор, сверхмалая мощность, Iq 500 нА с выбираемым контактом, двухуровневое выходное напряжение 6-WSON от -40 до 125
TPS780xx 150-mA Low-Dropout Regulator, Ultralow-Power, IQ 500 nA With Pin-Selectable, Dual-Level Output Voltage datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 9 сен 2014
Pin | 6 |
Package Type | DRV |
Industry STD Term | WSON |
JEDEC Code | S-PDSO-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | OAI |
Width (мм) | 2 |
Length (мм) | 2 |
Thickness (мм) | .75 |
Pitch (мм) | .65 |
Max Height (мм) | .8 |
Mechanical Data | Скачать |
Точность | 3 % |
Fixed Output Options | 1.8,2,2.3,2.5,2.7,3,3.3 В |
Iout(Max) | 0.15 A |
Iq(Typ) | 0.0005 мА |
Noise | 86 uVrms |
Output Capacitor Type | Ceramic |
Output Options | Adjustable Output,Fixed Output |
PSRR @ 100KHz | 13 дБ |
Package Group | WSON |
Package Size: mm2:W x L | See datasheet (WSON) PKG |
Rating | Catalog |
Regulated Outputs | 1 |
Special Features | Enable,Output Discharge |
Thermal Resistance ОёJA | 66 В°C/W |
Vdo(Typ) | 200 мВ |
Vin(Max) | 5.5 В |
Vin(Min) | 2.2 В |
Vout(Max) | 5.25 В |
Vout(Min) | 1.2 В |
- Evaluation Modules & Boards: TPS780XXEVM-301
TPS780XXEVM-301 Evaluation Module
- Using power solutions to extend battery life in MSP430 applicationsPDF, 538 Кб, Файл опубликован: 4 окт 2009
- Q4 2009 Issue Analog Applications JournalPDF, 1.5 Мб, Файл опубликован: 4 окт 2009
- 3.6V - 5.5V Input LDO with Dual-Level Output Reference Design for MSP430 (Rev. A)PDF, 199 Кб, Версия: A, Файл опубликован: 14 июн 2010
This reference design is presented to help application designers and others who are trying to use the MSP430 in a system with an input voltage in the range of 3.6 V to 5.5 V and who are also interested in using an easy-to-use low-dropout linear regulator (LDO) for a simple design with extended battery life by putting the MSP430 into a low-power state between operating states.
Серия: TPS780 (25)
- TPS78001DDCR TPS78001DDCRG4 TPS78001DDCT TPS78001DDCTG4 TPS78001DRVR TPS78001DRVRG4 TPS78001DRVT TPS78001DRVTG4 TPS780180300DRVR TPS780180300DRVT TPS780230300DRVR TPS780230300DRVT TPS780270200DDCR TPS780270200DDCT TPS780300250DRVR TPS780300250DRVT TPS780330200DDCR TPS780330200DDCT TPS780330220DDCR TPS780330220DDCT TPS780330220DDCTG4 TPS780330220DRVR TPS780330220DRVRG4 TPS780330220DRVT TPS780330220DRVTG4
