Datasheet Texas Instruments TPS62113RSAR — Даташит
СерияTPS62113
МодельTPS62113RSAR
Понижающий преобразователь, 1,5 А, 17 В с функцией LBI в QFN-16 16-QFN от -40 до 85
TPS6211x 17-V, 1.5-A, Synchronous Step-Down Converter datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 18 июн 2015
Pin1616
Package TypeRSARSA
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаTPS62113
Width (мм)44
Length (мм)44
Thickness (мм).9.9
Pitch (мм).65.65
Max Height (мм)11
Control ModeVoltage Mode
Duty Cycle(Max)100 %
Iout(Max)1.5 A
Iq(Typ)0.02 мА
Package GroupQFN
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Light Load Efficiency,Power Good,Synchronous Rectification
Switching Frequency(Max)1100 kHz
Switching Frequency(Min)900 kHz
ТипConverter
Vin(Max)17 В
Vin(Min)3.1 В
Vout(Max)16 В
Vout(Min)1.2 В
  • Evaluation Modules & Boards: TPS62113EVM-465
    TPS62113EVM-465 Evaluation Module
  • Evaluation Modules & Boards: TPS62110EVM-346
    TPS62110 0.5A to 1.5A Low Profile White LED Driver Configuration Evaluation Module
  • Adding Hysteresis to Low-Battery Input on the TPS6211x
    PDF, 88 Кб, Файл опубликован: 2 ноя 2009
    The low-battery input (LBI), available on several step-down converters, is often used to shut down the converter when the input voltage falls below a set threshold. This prevents damage to the battery and signals that the battery is at the end of its life and must be charged or replaced. Batteries have internal resistance that causes the voltage to drop as the load increases. This internal resista
  • TPS6211X Driving EN and SYNC pin
    PDF, 70 Кб, Файл опубликован: 15 янв 2008
    The TPS6211x high-input-voltage buck converters operate over a wide, input-voltage range. The control and input signal can also be controlled from 1.8-V logic levels up to maximum input voltage.One characteristic of the EN and SYNC control circuits is the increase in leakage current when these pins are driven by a voltage level less than 4 V.In this application report, the difference in th
  • Design considerations for a resistive feedback divider in a DC/DC converter
    PDF, 393 Кб, Файл опубликован: 26 апр 2012
  • Five steps to a great PCB layout for a step-down converter
    PDF, 162 Кб, Файл опубликован: 29 янв 2015
  • Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)
    PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
  • Testing tips for applying external power to supply outputs without an input volt
    PDF, 110 Кб, Файл опубликован: 24 окт 2016
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
Серия: TPS62113 (2)
На английском языке: Datasheet Texas Instruments TPS62113RSAR
