Datasheet Texas Instruments UC2842DTR — Даташит
СерияUC2842
МодельUC2842DTR
ШИМ-контроллер токового режима 14-SOIC от -40 до 85
UCx84x Current-Mode PWM Controllers datasheet
PDF, 3.8 Мб, Версия: E, Файл опубликован: 6 янв 2017
Pin14
Package TypeD
Package QTY2500
МаркировкаUC2842D
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Control MethodPeak Current Mode
Duty Cycle(Max)100 %
Frequency(Max)500 kHz
Frequency(Min)26 kHz
Gate Drive(Typ)1 A
Special FeaturesError Amplifier,Multi-topology
TopologyBoost,Buck,Buck-Boost,Flyback,Forward
UVLO Thresholds On/Off16/10 В
Vin(Max)400 В
Vin(Min)16 В
  • U-100A UC3842/3/4/5 Provides Low-Cost Current-Mode Control
    PDF, 507 Кб, Файл опубликован: 5 сен 1999
    The fundamental challenge of power supply design is to realize simultaneously two conflicting objectives: good electrical performance and low cost. The UC3842/3/4/5 control ICs are integrated pulse-width modulators (PWMs). These inexpensive IC controllers provide all the performance advantages of current-mode operation. In addition the UC3842 series is optimized for efficient power-sequencing of
  • DN-40 The Effects of Oscillator Discharge Current Variations on Maximum Duty
    PDF, 39 Кб, Файл опубликован: 5 сен 1999
    This design note details programming frequency and maximum duty cycle using the UC3842 and UC3842-A PWM oscillator ICs. Simplified equations are used to develop obtainable ranges for parameters over IC tolerances.
  • DN-27 UC1842/UC1842A Family - Summary of Functional Differences
    PDF, 21 Кб, Файл опубликован: 5 сен 1999
    The UC1842A/3A/4A/5A family of control ICs is a pin-for-pin compatible improved version of the UC3842/3/4/5 family. Providing the necessary features to control current-mode switched-mode power supplies this device has been improved for higher frequency off-line power supplies. This new A series of controllers UC1842A/43A/44A/45A is superior to its predecessors in startup current requirements
  • DN-26 UC3842A Low-Cost Start-up and Fault Protection Circuit
    PDF, 155 Кб, Файл опубликован: 5 сен 1999
    The UC1842/3/4/5 family of control ICs can implement off-line or DC-to-DC fixed-frequency current-mode control schemes with a minimal external parts count. This design note describes a circuit with low startup current (less than 0.5mA) MOSFET-compatible undervoltage lockout thresholds programmable restart-delay HICCUP fault protection auxiliary 5V precision reference and overvoltage/overtemper
  • DN-65 Considerations in Powering BiCMOS ICs
    PDF, 100 Кб, Файл опубликован: 5 сен 1999
    Bipolar linear integrated circuits have been with us for years in the form of PWM and PFC controllers supervisory circuits and other circuits. Since these devices have traditionally used relatively high-voltage (35V) bipolar processes powering was not a concern. In addition many of these ICs contained high-current protection zeners to keep higher voltages from damaging the devices. With a numb
  • DN-62 Switching Power Supply Topology Voltage Mode vs. Current Mode
    PDF, 66 Кб, Файл опубликован: 5 сен 1999
    This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
  • UCC38C42 Family of High-Speed BiCMOS Current-Mode PWM Controllers
    PDF, 280 Кб, Файл опубликован: 7 фев 2002
    Since their introduction in the mid 1980?s the bipolar UC3842 family of Pulse width modulation (PWM)controllers has grown to become the most widely-used control strategy in the power supply industry. [1] The reasons for success are quite clear the devices feature an elegantly simple yet very effective control architecture they use only 8 pins they can drive MOSFET gates directly and they offer
  • U-111 Practical Considerations in Current Mode Power Supplies
    PDF, 787 Кб, Файл опубликован: 5 сен 1999
    This application note explains the numerous PWM functions and ways to maximize their usefulness. It covers practical circuit design considerations such as slope compensation gate drive circuitry external control functions synchronization and paralleling current-mode controlled modules. Circuit diagrams and simplified equations are included.
  • DN-42A Design Considerations for Transitioning from UC3842 to the New UCC3802
    PDF, 42 Кб, Файл опубликован: 5 сен 1999
    The UCC3802 offers numerous advantages that allow the power supply design engineer to meet requirements for lower power for battery-operated equipment higher switching frequencies for reduced magnetics size higher levels of circuit integration for improved reliability and lower cost. The UCC3802 family of devices is pin-out compatible with the UC3842 and UC3842A families; however it is not plu
  • Conditioning a Switch-mode Power Supply Current Signal Using TI Op Amps
    PDF, 61 Кб, Файл опубликован: 23 мар 2000
    The switch-mode power supply primary current is often sensed using a power resistor. Using an op amp to amplify the current-sense signal can reduce cost and improve noise performance and efficiency. This report reviews the advantages of using an op amp circuit and analyzes the design criteria needed to choose the proper op amp.
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UC2842DTR
