Datasheet Texas Instruments MSP430F67491AIPZR — Даташит
СерияMSP430F67491A
МодельMSP430F67491AIPZR
MSP430F67491A Микроконтроллер смешанных сигналов 100-LQFP от -40 до 85
MSP430F677x1A, MSP430F676x1A, MSP430F674x1A Polyphase Metering SoCs datasheet
PDF, 2.9 Мб, Файл опубликован: 28 май 2014
IC MCU 16BIT 512KB FLASH 100LQFP. CPUXV2 MSP430F6xx Microcontroller IC 16-Bit 25MHz 512KB (512K x 8) FLASH 100-LQFP (14x14). Embedded -...
MSP430F67491AIPZR
431 ₽
MSP430F67491AIPZR
963 ₽
MSP430F67491AIPZR
7 585 ₽
727GS
MSP430F67491AIPZR
Pin100
Package TypePZ
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаF67491A
Width (мм)14
Length (мм)14
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
ADCADC10 - 6ch,SigmaDelta24 - 4ch
AESN/A
Active Power346.8 uA/MHz
Additional FeaturesLCD,Real-Time Clock,Watchdog,Temp Sensor,Brown Out Reset,IrDA
BSLUART
CPUMSP430
DMA3
Featuredf6
Тактовая частота25 МГц
GPIO Pins90
I2C2
Max VCC3.6
Min VCC1.8
Multiplier32x32
Non-volatile Memory512 KB
Package GroupLQFP
Package Size: mm2:W x L100LQFP: 256 mm2: 16 x 16(LQFP) PKG
RAM32 KB
SPI6
Special I/ON/A
Standby Power2.9 LPM3-uA
Timers - 16-bit4
UART4
Wakeup Time5 us
  • Development Kits: MSP-TS430PEU128
    MSP-TS430PEU128 - 128-pin Target Development Board for MSP430F6x MCUs
  • Evaluation Modules & Boards: EVM430-F6779
    EVM430-F6779 - 3 Phase Electronic Watt-Hour EVM for Metering
  • Development Kits: MSP-FET430U128
    128-pin Target Development Board and MSP-FET Programmer Bundle for MSP430F6x MCUs
    MSP EnergyTrace Technology
  • Differences Between MSP430F67xx and MSP430F67xxA Devices
    PDF, 3.5 Мб, Файл опубликован: 30 мар 2015
    This application report describes the enhancements of the MSP430F67xxA devices from the non-A MSP430F67xx devices. In the course of this application report, the MSP430F67xx errata that are fixed in the MSP430F67xxA and the additional features added to the MSP430F67xxA devices are discussed. In addition, metrology results are compared to further show that the changes implemented in the MSP430F67xxA
  • Designing With MSP430 and Segment LCDs (Rev. A)
    PDF, 2.1 Мб, Версия: A, Файл опубликован: 20 июл 2015
    Segment liquid crystal displays (LCDs) are needed to provide information to users in a wide variety of applications from smart meters to electronic shelf labels (ESL) to medical equipment. Several MSP430в„ў microcontroller families include built-in low-power LCD driver circuitry that allows the MSP430 MCU to directly control the segmented LCD glass. This application note helps explain how segmented
  • General Oversampling of MSP ADCs for Higher Resolution (Rev. A)
    PDF, 551 Кб, Версия: A, Файл опубликован: 1 апр 2016
    Multiple MSP ultra-low-power microcontrollers offer analog-to-digital converters (ADCs) to convert physical quantities into digital numbers, a function that is widely used across numerous applications. There are times, however, when a customer design demands a higher resolution than the ADC of the selected MSP can offer. This application report, which is based on the previously-published Oversampl
  • MSP Code Protection Features
    PDF, 752 Кб, Файл опубликован: 7 дек 2015
    MSP microcontrollers (MCUs) offer a number of features to help control code accessibility in the device, to add different layers of code access management and protection strategies. These include features that can lock or password protect the JTAG/SBW access, IP Encapsulation (IPE) to isolate sensitive code with different permissions than the rest of the program, and bootloader (BSL) access featur
  • ESD Diode Current Specification
    PDF, 520 Кб, Файл опубликован: 7 дек 2015
    This document explains the maximum ESD diode current specified for GPIO on MSP microcontrollers. Sometimes signals on specific pins exceed the supply of the MSP MCU. In such a case, the device can handle this overvoltage condition through the ESD diodes, but the ESD diode specification must be considered during application design. The items to be considered are described in this document.
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430F5x/6x
На английском языке: Datasheet Texas Instruments MSP430F67491AIPZR
