Datasheet Texas Instruments LM1771USD/NOPB — Даташит
СерияLM1771
МодельLM1771USD/NOPB
Низковольтный синхронный понижающий контроллер с прецизионным включением и без внешней компенсации 6-WSON от -40 до 125
LM1771 Low-Voltage Synchronous Buck Controller With Precision Enable and No External Compensation datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 8 янв 2016
Pin6
Package TypeNGG
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY1000
CarrierSMALL T&R
Маркировка1771U
Width (мм)3
Length (мм)3
Thickness (мм).8
Pitch (мм).95
Max Height (мм).8
Control ModeConstant on-time (COT)
Duty Cycle(Max)98 %
Iout(Max)6 A
Iq(Typ)0.4 мА
Number of Phases1
Package GroupWSON
Regulated Outputs1
Special FeaturesEnable
Switching Frequency(Max)2000 kHz
Switching Frequency(Min)500 kHz
ТипController
Vin(Max)5.5 В
Vin(Min)2.8 В
Vout(Max)4.5 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: LM1771EVAL
    Low-Voltage Synchronous Buck Controller with Precision Enable and No External Compensation
  • LM1771 and LM3880 Based FPGA Power Supply Reference Design (Rev. A)
    PDF, 103 Кб, Версия: A, Файл опубликован: 5 май 2013
    This application note discusses the Virtex-5 FPGA power supply prerequisites in terms of the multiplevoltage rail and current level requirements, output sequencing, and startup characteristics.
  • Controlling Output Ripple & Achiev ESR Indep Constant On-Time Reg Designs (Rev. A)
    PDF, 178 Кб, Версия: A, Файл опубликован: 23 апр 2013
    Of all the voltage regulator control strategies ever devised, the hysteretic regulator is probably about thesimplest. This control methodology simply turns a switch on when the output voltage is below a referenceand turns the switch off when the output rises to a slightly higher reference. The output ripple is thereforea direct function of the difference between the upper and lower reference
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments LM1771USD/NOPB
