Datasheet Texas Instruments OPA541APG3 — Даташит
СерияOPA541
МодельOPA541APG3
Монолитный операционный усилитель высокой мощности 11-TO-220 от -25 до 85
OPA541 High Power Monolithic Operational Amplifier datasheet
PDF, 409 Кб, Версия: B, Файл опубликован: 7 апр 2015
Pin11
Package TypeKV
Industry STD TermTO-220
JEDEC CodeR-PZFM-T
Package QTY25
МаркировкаOPA541AP
Width (мм)10.7
Length (мм)20.02
Thickness (мм)4.5
Pitch (мм)1.7
Max Height (мм)4.62
Additional FeaturesAdj Current Limit
АрхитектураFET
CMRR(Min)95 дБ
CMRR(Typ)113 дБ
GBW(Typ)2 МГц
Input Bias Current(Max)50 pA
Iq per channel(Max)25 мА
Iq per channel(Typ)20 мА
Количество каналов1
Offset Drift(Typ)15 uV/C
Рабочий диапазон температурот -25 до 85 C
Output Current(Typ)10000 мА
Package GroupTO-220
Package Size: mm2:W x LSee datasheet (TO-220) PKG
Rail-to-RailNo
Slew Rate(Typ)10 V/us
Total Supply Voltage(Max)70 +5V=5, +/-5V=10
Total Supply Voltage(Min)20 +5V=5, +/-5V=10
Vos (Offset Voltage @ 25C)(Max)1 мВ
  • Evaluation Modules & Boards: OPAMPEVM
    Universal Operational Amplifier Evaluation Module
  • Improve OPA541 Current-Limit Stability
    PDF, 31 Кб, Файл опубликован: 2 окт 2000
    OPA541 is the industry's highest performance monolithic power amplifier. It can operate on В±40V power supplies and put out 5A continuously (10A peak). Internal current-limit circuitry can be user-programmed with a single external resistor to protect the amplifier and load from fault conditions.
  • Mounting Considerations for TO-3 Packages
    PDF, 73 Кб, Файл опубликован: 27 сен 2000
    Proper mounting of TO-3 packages is required to assure rated performance and reliability. Although the procedures are simple, ignoring them can result in poor performance and catastrophic failure of the device.
  • MTTF, Failrate, Reliability, and Life Testing
    PDF, 51 Кб, Файл опубликован: 4 окт 2000
    At Burr-Brown, we characterize and qualify the reliability of our devices through high temperature life testing. The results of this testing are quantified with such values as MTTF and failure rate. This information can be very valuable when used for comparative purposes or applied to reliablility calculations. However, this information loses its worth if it is not precisely understood and appropr
  • Power Amplifier Stress and Power Handling Limitations
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
На английском языке: Datasheet Texas Instruments OPA541APG3
