Datasheet Texas Instruments OPA124U/2K5 — Даташит
СерияOPA124
МодельOPA124U/2K5
Малошумящий прецизионный операционный усилитель Difet 8-SOIC от -25 до 85
Low Noise Precision Difet® Operational Amplifier datasheet
PDF, 287 Кб, Файл опубликован: 27 сен 2000
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка124UOPA
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Additional FeaturesN/A
АрхитектураFET
CMRR(Min)86 дБ
CMRR(Typ)100 дБ
GBW(Typ)1 МГц
Input Bias Current(Max)1 pA
Iq per channel(Max)3.5 мА
Iq per channel(Typ)2.5 мА
Количество каналов1
Offset Drift(Typ)1 uV/C
Рабочий диапазон температурот -25 до 85 C
Output Current(Typ)40 мА
Rail-to-RailOut
Slew Rate(Typ)1.6 V/us
Total Supply Voltage(Min)10 +5V=5, +/-5V=10
Vn at 1kHz(Typ)8 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.25 мВ
  • Comparison of Noise Performance of FET Transimpedence Amp/Switched Integrator
    PDF, 66 Кб, Файл опубликован: 27 сен 2000
    Low-input current FET operational amplifiers are universlly used to monitor photodetector, or more commonly photodiode currents. These photodetectors bridge the gap between a physical event, light, and electronics. There are a variey of amplifier configurations to select from and the choice is based on noise, bandwidth, offset, and linearity. A considerable amount has been written on the performan
  • Tuning in Amplifiers
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Diode-Connected FET Protects Op Amps
    PDF, 49 Кб, Файл опубликован: 2 окт 2000
    Providing input-overload protection for sensitive measurement circuits proves difficult when you must not degrade the circuits? performance in the process. It?s an especially tricky problem when you?re measuring a material?s dielectric properties. In such an application, an ultra-low input bias current op amp serves as a current integrator to measure a dielectric?s response to a 100V step.
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA124U/2K5
