Datasheet Texas Instruments OPA2658E/2K5 — Даташит
СерияOPA2658
МодельOPA2658E/2K5
Двойной широкополосный маломощный операционный усилитель с токовой обратной связью 8-VSSOP
Datasheet
TSP
Package TypeDGK
Industry STD TermVSSOP
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Рекомендуемая замена
ReplacementOPA2658U
Replacement CodeF
RoHSНе совместим
  • Evaluation Modules & Boards: DEM-OPA268XU
    DEM-OPA268xU: Demonstration Fixture
  • Evaluation Modules & Boards: DEM-OPA26XXE
    DEM-OPA26xxE: Demonstration Fixture
  • Tuning in Amplifiers
  • The Current-Feedback Op Amp: A High-Speed Building Block
    PDF, 117 Кб, Файл опубликован: 2 окт 2000
    Although current-feedback amplifiers (CFAs) have been in use for quite some time, there is a reluctance to view them in the same light as voltage-feedback amplifiers (VFAs). For instance, the gain-bandwidth curve of VFAs has a parallel in a transimpedance-bandwidth curve for CFAs. This parameter can be used to determine the closed-loop behavior of the CFA in same way that GBW can for the VFA. Not
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA2658E/2K5
