Линейка продуктов KEEN SIDE
Datasheet Texas Instruments OPA128KM — Даташит
СерияOPA128
МодельOPA128KM
Операционный усилитель Difet электрометрического класса 8-TO-99 от -55 до 125
Datasheet OPA128
PDF, 138 Кб, Файл опубликован: 27 сен 2000, Страниц: 11
Difet Electrometer-Grade Operational Amplifier
Package TypeLMC
Industry STD TermTO-CAN
JEDEC CodeO-MBCY-W
Package QTY20
МаркировкаOPA128KM
Width (мм)9.08
Length (мм)9.08
Thickness (мм)4.4
Pitch (мм)2.54
Max Height (мм)5.72
Additional FeaturesN/A
АрхитектураFET
CMRR(Min)80 дБ
CMRR(Typ)118 дБ
GBW(Typ)1 МГц
Input Bias Current(Max)0.075 pA
Iq per channel(Max)1.8 мА
Iq per channel(Typ)0.9 мА
Количество каналов1
Offset Drift(Typ)5 uV/C
Output Current(Typ)34 мА
Package GroupTO-99
Package Size: mm2:W x L8TO-99: 80 mm2: 8.96 x 8.96(TO-99) PKG
Rail-to-RailOut
Slew Rate(Typ)3 V/us
Total Supply Voltage(Min)10 +5V=5, +/-5V=10
Vn at 1kHz(Typ)27 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.5 мВ
  • Designing Photodiode Amplifier Circuits with OPA128
    The OPA128 ultra-low bias current operational amplifier achieves its 75fA maximum bias current without compromise. Using standard design techniques, serious performance trade-offs were required which sacrificed overall amplifier performance in order to reach femtoamp (fA = 10-15A) bias currents.
  • Diode-Connected FET Protects Op Amps
    PDF, 49 Кб, Файл опубликован: 2 окт 2000
    Providing input-overload protection for sensitive measurement circuits proves difficult when you must not degrade the circuits? performance in the process. It?s an especially tricky problem when you?re measuring a material?s dielectric properties. In such an application, an ultra-low input bias current op amp serves as a current integrator to measure a dielectric?s response to a 100V step.
  • Boost Instrument Amp CMR With Common-Mode Driven Supplies
    PDF, 175 Кб, Файл опубликован: 27 сен 2000
    Ever-increasing demands are being placed on instrumentation amplifier (IA) performance. When standard IAs can not deliver the required performance, consider this enhanced version. Dramatic performance improvements can be achieved by operating the input amplifiers of a classical three-op-amp IA from common-mode driven sub-regulated power supplies.
  • Comparison of Noise Performance of FET Transimpedence Amp/Switched Integrator
    PDF, 66 Кб, Файл опубликован: 27 сен 2000
    Low-input current FET operational amplifiers are universlly used to monitor photodetector, or more commonly photodiode currents. These photodetectors bridge the gap between a physical event, light, and electronics. There are a variey of amplifier configurations to select from and the choice is based on noise, bandwidth, offset, and linearity. A considerable amount has been written on the performan
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
Серия: OPA128 (4)
На английском языке: Datasheet Texas Instruments OPA128KM
