Datasheet Texas Instruments TPS61163AYFFR — Даташит
СерияTPS61163A
МодельTPS61163AYFFR
Драйверы двухканальных WLED для смартфонов 9-DSBGA от -40 до 85
TPS6116xA Dual-Channel WLED Drivers For Smart Phones datasheet
PDF, 1.8 Мб, Версия: A, Файл опубликован: 18 июн 2015
Pin99
Package TypeYFFYFF
Industry STD TermDSBGADSBGA
JEDEC CodeS-XBGA-NS-XBGA-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаTPS61163A
Width (мм)1.41.4
Length (мм)1.41.4
Thickness (мм).425.425
Pitch (мм).4.4
Max Height (мм).625.625
Количество каналов2
Duty Cycle(Max)99.5 %
LED20
LED Current Per Channel30 мА
Package GroupDSBGA
Peak Efficiency90 %
Shutdown Current(Typ)1 uA
Special FeaturesEasyScale 1-Wire Interface,Enable/Shutdown,OVP,PWM Control,Soft Start,Thermal Shutdown
Switching Frequency(Max)1200 kHz
TopologyBoost
ТипInductive
Vin(Max)6.5 В
Vin(Min)2.7 В
Vout(Max)37.5 В
Vout(Min)2.7 В
  • Evaluation Modules & Boards: TPS61163AEVM-564
    Dual-Channel WLED Drivers For Smart Phone Evaluation Module
  • Simple Backlight Driver Dimming Performance
    PDF, 74 Кб, Файл опубликован: 20 мар 2017
    The TPS61158, TPS61160/61, TPS61162/63A, TPS61165, and TPS61169 (hereafter TPS611xx) are simple backlight drivers commonly used in smartphones and tablets. These devices support PWM dimming with an input voltage as low as 2.7 V. This application note discusses the requirements for using tje TPS611xx parts at the lowest performance specifications for PWM dimming.
  • Analog PWM Dimming in White-LED Drivers
    PDF, 539 Кб, Файл опубликован: 21 дек 2016
    Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in
Серия: TPS61163A (1)
  • TPS61163AYFFR
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments TPS61163AYFFR
