Datasheet Texas Instruments TM4C123GH6ZXRT7R — Даташит
СерияTM4C123GH6ZXR
МодельTM4C123GH6ZXRT7R
Высокопроизводительный 32-битный микроконтроллер на базе ARM® Cortex®-M4F 168-NFBGA от -40 до 105
Tiva C Series TM4C123GH6ZXR Microcontroller Data Sheet datasheet
PDF, 8.6 Мб, Версия: A, Файл опубликован: 20 июн 2014
Pin168168
Package TypeZXRZXR
МаркировкаTM4C123GH6ZXRT7
Width (мм)77
Length (мм)77
Thickness (мм).8.8
10/100 ENET MACNo
10/100 ENET MAC+PHYNo
ADC Channels24
ADC Resolution12 Bits
Bi- and Quad- SSI/SPINo
CAN MAC2
CPUARM Cortex-M4F
External Peripheral InterfaceNo
Flash256 KB
Тактовая частота80 МГц
GPIO120
I2C6
LCD ControllerNo
Max Speed80 МГц
Motion PWM Outputs16
Non-volatile Memory2 KB
Package GroupNFBGA
Package Size: mm2:W x L168NFBGA: 49 mm2: 7 x 7(NFBGA) PKG
Pin & Package168BGA
Pin/Package168NFBGA
QEI2
RAM32 KB
SPI4
SRAM32 kB
SSI/SPI4
SecurityNo HW accelerator
SysTickYes
UART8
USB D, H/D, or OTGOTG
USB High-Speed with ULPINo
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-ARM
    XDS100v2 JTAG Debug Probe (ARM version)
  • Evaluation Modules & Boards: EK-TM4C123GXL
    ARMВ® CortexВ®-M4F Based MCU TM4C123G LaunchPadВ™ Evaluation Kit
  • Development Kits: DK-TM4C123G
    TM4C123G USB+CAN Development Kit
  • Evaluation Modules & Boards: EK-TM4C129EXL
    ARMВ® CortexВ®-M4F-Based MCU TM4C129E Crypto Connected LaunchPadв„ў for IoT Applications
  • Evaluation Modules & Boards: EK-TM4C1294XL
    ARMВ® CortexВ®-M4F-Based MCU TM4C1294 Connected LaunchPadв„ў
  • Development Kits: BOOSTXL-EDUMKII
    Educational BoosterPack MKII
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
    XDS200 USB Debug Probe
  • Using TM4C12x Devices Over JTAG Interface
    PDF, 1.9 Мб, Файл опубликован: 18 авг 2016
    The IEEE Standard 1149.1-1990, IEEE Standard Test Access Port and Boundary-Scan Architecture (JTAG) is a method for verifying designs and testing printed circuit boards after assembly. It is used as the primary means for transferring data to a nonvolatile memory of an embedded system and debugging embedded software.This application report describes the physical connections for JTAG and desi
  • StellarisВ® Graphics Library Display Drivers (AN01287) (Rev. A)
    PDF, 67 Кб, Версия: A, Файл опубликован: 9 июл 2013
    The Stellaris Graphics Library (grlib) offers a compact yet powerful collection of graphics functions allowing the development of compelling user interfaces on small monochrome or color displays attached to Stellaris microcontrollers. This application report describes how to support a new display device in the Stellaris Graphics Library.
  • Transitioning Designs From Stellaris LM3S Microcontrollers to Tiva C Series MCUs (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 22 окт 2013
    This application report addresses design considerations when migrating working designs from Stellaris LM3S microcontrollers to Tiva C Series microcontrollers. Topics covered include software and hardware considerations as well as feature changes and enhancements. Software migration is very straightforward when using the Driver Library APIs in the StellarisWareВ® and TivaWareв„ў for C Series
  • System Design Guidelines for the TM4C123x Family of Tiva C Series MCUs
    PDF, 1.5 Мб, Файл опубликован: 31 июл 2013
  • Migrating Software Projects from StellarisWare to TivaWare for C Series Software (Rev. A)
    PDF, 92 Кб, Версия: A, Файл опубликован: 1 май 2013
    As TI launches the Tivaв„ў family of 32-bit ARMВ® Cortexв„ў-M4 microcontrollers (MCUs), the StellarisWareВ® suite of comprehensive software tools is also migrating to TivaWareв„ў. This new software platform offers the same features found in earlier versions, but a few changes have been made in the migration process that require simple modifications to be made in existing StellarisWare applications in orde
  • Using the CMSIS DSP Library in Code Composer Studio for TM4C MCUs (Rev. G)
    PDF, 3.0 Мб, Версия: G, Файл опубликован: 7 окт 2015
    This application report describes the process required to build the ARMВ® CMSIS DSP library in Code Composer Studio v6.1 with ARM Compiler version up to 5.2.5. This document also describes how to use Code Composer Studio v6.1 to build, run, and verify the 11 ARM DSP example projects that are included in the CMSIS package.
  • Powering Cortex-M4 MCUs Using the High Efficiency DCS-Control Topology
    PDF, 164 Кб, Файл опубликован: 3 фев 2013
    The new Tiva C Series ARMВ® Cortexв„ў-M4 family of versatile microcontrollers provides prolific connectivity peripherals, such as the industry's first integrated Ethernet MAC and PHY, advanced analog integration and hardware floating-point performance. This application report presents an ultra-low IQ (4.8 ОјA) power supply solution for Tiva C Series devices using the TPS62177, a high efficiency synchr
  • Dual-SPI Emulating IВІS on Tivaв„ў C Series TM4C123x MCUs (Rev. B)
    PDF, 436 Кб, Версия: B, Файл опубликован: 12 июн 2013
    This application report presents an example using two serial peripheral interfaces (SPIs) to emulate an integrated interchip sound (I2S) peripheral on the StellarisВ® LM4F232 (Tiva C series TM4C123GH6PGE) microcontroller. Utilizing the sound API, .wav audio files stored in the on-board SD card are played via pseudo-I2S to an external Texas Instruments' TLV320AIC3107 codec. This generic software pla
  • Using AES Encryption and Decryption with Stellaris Microcontrollers (AN01251) (Rev. B)
    PDF, 113 Кб, Версия: B, Файл опубликован: 8 янв 2010
    This application note describes the following four encryption methods used with AES: Electronic code book (ECB), cipher block chaining (CBC) or chained encryption, cipher feedback (CFB), and counter (CTR). These methods are described in more detail to help you select the appropriate method(s) for your application. The encryption package described in this application note is available with full sou
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Control + Automation > TM4C12x
На английском языке: Datasheet Texas Instruments TM4C123GH6ZXRT7R
