Datasheet Texas Instruments TPS7150QP — Даташит
СерияTPS71
МодельTPS7150QP
Стабилизатор напряжения 8-PDIP, 500 мА с низким падением напряжения от -40 до 125
Low-Dropout Voltage Regulators datasheet
PDF, 1.3 Мб, Версия: G, Файл опубликован: 22 янв 2003
31 предложений от 18 поставщиков
Чип стабилизации напряжения, Dual Channel LDO Lowest Dropout (LDO) PMOS Voltage Regulator LDO Regulator Pos 5V 0.5A 8Pin PDIP Tube
TPS7150QP
51 ₽
TPS7150QP
254 ₽
TPS7150QP
от 1 324 ₽
SUV System
TPS7150QP
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Точность3 %
Основные особенностиEnable,Power Good
Fixed Output Options3.3,4.8,5 В
Iout(Max)0.5 A
Iq(Typ)0.28 мА
Noise89 uVrms
PSRR @ 100KHz3 дБ
Package GroupPDIP
Regulated Outputs1
Thermal Resistance ОёJA106 В°C/W
Vdo(Typ)235 мВ
Vin(Max)10 В
Vin(Min)2.5 В
Vout(Max)9.75 В
Vout(Min)1.2 В
  • TMS320C62x/67x Power Supply Solutions for 1-2 DSPs Using the TL5001A and TPS7133 (Rev. A)
    PDF, 190 Кб, Версия: A, Файл опубликован: 1 июн 1999
    This application report describes a low-cost power solution for Texas Instruments' TMS320C6000 DSP applications using the TL5001PWM controller and the TPS7133 low drop-out voltage regulator. The reference design included in this report uses the TL5001AEVM-122 (SLVP122) evaluation module (EVM) which is available for customer testing and evaluation.
  • Power Supply Sequencing Solutions for Dual Supply Voltage DSPs (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 5 июл 2000
    This application report describes power-supply sequencing recommendations and techniques applicable to dual supply voltage DSPs in TI's TMS320C2000 TMS320C5000 and TMS320C6000 families. These techniques take advantage of the reset power good enable and soft-start features available on TI Power Management Products including low drop out regulators switching power supply controllers supply vol
  • Technical Review of Low Dropout Voltage Regulator Operation And Performance
    PDF, 284 Кб, Файл опубликован: 30 авг 1999
    This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators.
  • Fundamental Theory of PMOS LDO Voltage Regulators
    PDF, 66 Кб, Файл опубликован: 7 май 1999
    This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements.
На английском языке: Datasheet Texas Instruments TPS7150QP
