Datasheet Texas Instruments UCC28070PWR — Даташит
СерияUCC28070
МодельUCC28070PWR
Двухфазный контроллер CCM PFC с чередованием 20-TSSOP от -40 до 125
UCC28070 Interleaving Continuous Conduction Mode PFC Controller datasheet
PDF, 1.9 Мб, Версия: F, Файл опубликован: 18 апр 2016
Ruimeng предлагает удачную замену популярной микросхеме Axx1248 – 24-битный Σ-Δ АЦП MS5148T
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY2000
Маркировка28070
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Control MethodCCM
Device TypeInterleaved PFC
Operating Supply Current20 мА
Operating Supply(Max)21 В
Package GroupTSSOP
Peak Output Sink Current Gate Drive0.75 A
Peak Output Source Current Gate Drive-0.75 A
Practical Operating Frequency(Max)0.3 МГц
Special Features> 750W Applications,Average Current Mode,Interleaved,OVP
Startup Current20 мА
UVLO Thresholds On/Off10.2/9.2 В
  • Evaluation Modules & Boards: UCC28070EVM
    UCC28070 Evaluation module
  • UCC28070 300W Interleaved PFC Pre-regulator Design Review (Rev. B)
    PDF, 753 Кб, Версия: B, Файл опубликован: 8 июл 2010
    In higher power applications to utilize the full line power and reduce line current harmonics PFC Pre-regulators are generally required. In these high power applications interleaving PFC stages can reduce inductor volume and reduce input and output capacitor ripple current. This results in smaller overall magnetic volume and filter capacitor volume increasing the converters overall power density.
  • UCC28070 Implement Bridgeless PFC Pre-Regulator Design
    PDF, 739 Кб, Файл опубликован: 18 июн 2009
    Bridgeless power factor correction (PFC) topology is attracting attention as a means of satisfying the new high-efficiency requirements. This application report reviews the UCC28070 and its design considerations for bridgeless PFC. It present a bridgeless solution that is relatively easy to implement in that it does not require any additional circuitry for current sensing and that the operation re
Серия: UCC28070 (6)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
На английском языке: Datasheet Texas Instruments UCC28070PWR
