Datasheet Texas Instruments OPA362AIDCKT — Даташит
| Серия | OPA362 |
| Модель | OPA362AIDCKT |
Видеоусилитель 3 В с внутренним усилением и фильтром в SC70 6-SC70 от -40 до 125
3V VIDEO AMPLIFIER with Internal Gain and Filter, in SC70 datasheet
PDF, 1.0 Мб, Файл опубликован: 29 сен 2009
Купить OPA362AIDCKT на РадиоЛоцман.Цены — от 29 до 113 ₽40 предложений от 15 поставщиков Интегральные микросхемы Линейные микросхемы - Усилители - Видеоусилители и Модули | |||
| OPA362AIDCKT Texas Instruments | 46 ₽ | ||
| OPA362AIDCKT Texas Instruments | от 78 ₽ | ||
| OPA362AIDCKT Texas Instruments | от 112 ₽ | ||
| OPA362AIDCKT Texas Instruments | по запросу | ||
| Pin | 6 |
| Package Type | DCK |
| Industry STD Term | SOT-SC70 |
| JEDEC Code | R-PDSO-G |
| Package QTY | 250 |
| Carrier | SMALL T&R |
| Маркировка | OEA |
| Width (мм) | 1.25 |
| Length (мм) | 2 |
| Thickness (мм) | .9 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.1 |
| Mechanical Data | Скачать |
| Diff Gain | 1.2 % |
| Diff Phase | 1.6 deg |
| Количество каналов | 1 |
| Output Current(Typ) | 80 мА |
| Package Group | SC70 |
| Package Size: mm2:W x L | 6SC70: 4 mm2: 2.1 x 2(SC70) PKG |
| Rating | Catalog |
| Vs(Max) | 3.3 В |
| Vs(Min) | 2.5 В |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA362 (2)
- OPA362AIDCKR OPA362AIDCKT
- Semiconductors > Amplifiers > Special Function Amplifiers > Video Amplifiers
