Datasheet Texas Instruments SN74AVCA406EZQSR — Даташит
| Серия | SN74AVCA406E |
| Модель | SN74AVCA406EZQSR |
Трансивер преобразования напряжения для MMC и SD-карт 24-BGA MICROSTAR JUNIOR от -40 до 85
MMC and SD Card Voltage-Translation Transceiver datasheet
PDF, 970 Кб, Версия: E, Файл опубликован: 24 июн 2009
Купить SN74AVCA406EZQSR на РадиоЛоцман.Цены — от 61 до 213 ₽13 предложений от 13 поставщиков IC TRNSLTR BIDIRECTIONAL 24BGA. Voltage Level Translator Bidirectional 1 Circuit 4 Channel 24-BGA MICROSTAR JUNIOR (3x3). Logic - Translators, Level Shifters... | |||
| SN74AVCA406EZQSR Rochester Electronics | 88 ₽ | ||
| SN74AVCA406EZQSR Texas Instruments | 140 ₽ | ||
| SN74AVCA406EZQSR Texas Instruments | по запросу | ||
| Pin | 24 |
| Package Type | ZQS |
| Industry STD Term | BGA MICROSTAR JUNIOR |
| JEDEC Code | S-PBGA-N |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | WM406E |
| Width (мм) | 3 |
| Length (мм) | 3 |
| Thickness (мм) | .75 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1 |
| Mechanical Data | Скачать |
| Bits | 7 |
| ICCA Static Current | 0.01 мА |
| ICCB Static Current | 0.01 мА |
| Package Group | BGA MICROSTAR JUNIOR |
| Package Size: mm2:W x L | 20BGA MICROSTAR JUNIOR: 8 mm2: 3 x 2.5(BGA MICROSTAR JUNIOR) PKG |
| Rating | Catalog |
| Special Features | SD/SDIO/MMC Card |
| Static Current | 0.015 мА |
| VCCA(Max) | 3.6 В |
| VCCA(Min) | 1.2 В |
| VCCB(Max) | 3.6 В |
| VCCB(Min) | 1.2 В |
- Dynamic Output Control (DOC) Circuitry Technology And Applications (Rev. B)PDF, 126 Кб, Версия: B, Файл опубликован: 7 июл 1999
Texas Instruments (TI[TM]) next-generation logic is called the Advanced Very-low-voltage CMOS (AVC) family. The AVCfamily features TI?s Dynamic Output Control (DOC[TM]) circuit (patent pending). DOC circuitry automatically lowers the outputimpedance of the circuit at the beginning of a signal transition, providing enough current to achieve high signaling speeds, thensubsequently raises the i - AVC Logic Family Technology and Applications (Rev. A)PDF, 148 Кб, Версия: A, Файл опубликован: 26 авг 1998
Texas Instruments (TI?) announces the industry?s first logic family to achieve maximum propagation delays of less than 2 ns at 2.5 V. TI?s next-generation logic is the Advanced Very-low-voltage CMOS (AVC) family. Although optimized for 2.5-V systems, AVC logic supports mixed-voltage systems because it is compatible with 3.3-V and 1.8-V devices. The AVC family features TI?s Dynamic Output Control ( - Voltage Translation Between 3.3-V, 2.5-V, 1.8-V, and 1.5-V Logic Standards (Rev. B)PDF, 390 Кб, Версия: B, Файл опубликован: 30 апр 2015
- 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74AVCA406E (2)
- SN74AVCA406EZQSR SN74AVCA406EZXYR
- Semiconductors > Logic > Voltage Level Translation > Application Specific Voltage Translation
