Datasheet Texas Instruments LMH7324SQ/NOPB — Даташит
СерияLMH7324
МодельLMH7324SQ/NOPB
Счетверенный высокоскоростной компаратор 700 пс с выходами RSPECL 32-WQFN от -40 до 85
LMH7324 Quad 700 ps High Speed Comparator with RSPECL Outputs datasheet
PDF, 974 Кб, Версия: G, Файл опубликован: 18 мар 2013
25 предложений от 16 поставщиков
IC COMPARATOR QUAD 700PS 32WQFN. Comparator General Purpose Differential, LVDS, RSPECL 32-WQFN (5x5). Linear - Comparators
LMH7324SQ/NOPB
797 ₽
LMH7324SQ/NOPB
от 2 023 ₽
LMH7324SQ/NOPB
Hi-Tech Circuit Group
LMH7324SQ/NOPB
Pin32
Package TypeRTV
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY1000
CarrierSMALL T&R
МаркировкаL7324SQ
Width (мм)5
Length (мм)5
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Input Bias Current (+/-)(Max)5000 нА
Iq per channel(Max)6.25 мА
Количество каналов4
Тип выходаRSPECL
Package GroupWQFN
Package Size: mm2:W x L32WQFN: 25 mm2: 5 x 5(WQFN) PKG
Propagation Delay Time0.0007 uS
Rail-to-RailNo
Special FeaturesN/A
VICR(Max)10 В
Vos (Offset Voltage @ 25C)(Max)9.5 мВ
Vs(Max)12 В
Vs(Min)5 В
  • Evaluation Modules & Boards: LMH7324EVAL
    LMH7324 Quad 700ps High Speed Comparator with RSPECL Outputs Evaluation Board
  • Interface Circuits for TIA/EIA-644 (LVDS) (Rev. B)
    PDF, 69 Кб, Версия: B, Файл опубликован: 16 сен 2002
    This design note provides information concerning the designing of TIA/EIA-644 interface circuits. The TIA/EIA-644 standard is discussed including electrical characteristics, interconnections, line termination, and noise immunity. Finally, eye patterns are used to measure the effects of signal distortion, noise, signal attenuation, and the resultant intersymbol interference (ISI) in a data transmis
  • Interfacing Different Logic with LVDS Receivers
    PDF, 197 Кб, Файл опубликован: 14 май 2001
    This application report provides explanations and design considerations for interfacing RS-422, differential current mode logic (CML), differneital emitter coupled logic (ECL), and single-ended drivers with low-voltage differential signal (LVDS) receivers.
Серия: LMH7324 (2)
  • Semiconductors > Amplifiers > Comparators
На английском языке: Datasheet Texas Instruments LMH7324SQ/NOPB
