Datasheet ТI ADS7949SRTET — Даташит
СерияADS7949
МодельADS7949SRTET
Datasheet Texas Instruments ADS7949SRTET
8-битный, 2 MSPS, двухканальный, псевдодифференциальный, последовательный АЦП uPower SAR 16-WQFN от -40 до 125
12/10/8-Bit, 2MSPS, Dual-Ch, Unipolar, Pseudo-Diff, Ultralow-Power SAR ADCs datasheet
PDF, 874 Кб, Файл опубликован: 9 сен 2010
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS7949 (2)
На английском языке: Datasheet Texas Instruments ADS7949SRTET
Политика конфиденциальности
