Datasheet Texas Instruments SN74LVC00ADBRG4 — Даташит
СерияSN74LVC00A
МодельSN74LVC00ADBRG4
Четверной логический элемент положительного NAND с 2 входами 14-SSOP от -40 до 125
SNx4LVC00A Quadruple 2-Input Positive-NAND Gates datasheet
PDF, 1.4 Мб, Версия: R, Файл опубликован: 3 фев 2016
IC GATE NAND 4CH 2-INP 14SSOP. NAND Gate IC 4 Channel 14-SSOP. Logic - Gates and Inverters
SN74LVC00ADBRG4
7.79 ₽
SN74LVC00ADBRG4
Hi-Tech Circuit Group
SN74LVC00ADBRG4
727GS
SN74LVC00ADBRG4
Pin14
Package TypeDB
Industry STD TermSSOP
Package QTY2000
МаркировкаLC00A
Width (мм)5.3
Length (мм)6.2
Thickness (мм)1.95
Max Height (мм)2
Bits4
F @ Nom Voltage(Max)150 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Output Drive (IOL/IOH)(Max)24/-24 мА
Package GroupSSOP
Package Size: mm2:W x L14SSOP: 48 mm2: 7.8 x 6.2(SSOP) PKG
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)12.5,6.4,5.1,4.3 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Gate > NAND Gate
На английском языке: Datasheet Texas Instruments SN74LVC00ADBRG4
