Клеммники KEEN SIDE
Datasheet Texas Instruments TMS320LC542PGE1-50 — Даташит
СерияTMS320LC542
МодельTMS320LC542PGE1-50
Цифровой сигнальный процессор 144-LQFP
TMS320C54x, LC54x, VC54x Fixed-Point Digital Signal Processors datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 30 мар 1999
Pin144144
Package TypePGEPGE
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
МаркировкаTMS320LC54236928PGE1-50
Width (мм)2020
Length (мм)2020
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
  • Evaluation Modules & Boards: TMDSDSK5416
    TMS320C5416 DSP Starter Kit (DSK)
  • Calculation of TMS320LC54x Power Dissipation
    PDF, 235 Кб, Файл опубликован: 1 июн 1997
    Digital signal processor (DSP) applications continue to demand more from less: more features while consuming less power. The TMS320LC54x meets these challenges by combining high processing capability wth the greatly reduced power consumption that battery-powered and portable applications demand. This application report describes the power-saving features of the TMS320LC54x and presents techniq
  • TPS3801/09 - Smallest SVS for Monitoring DSPs and Processors
    PDF, 185 Кб, Файл опубликован: 2 сен 1999
    This application report describes the TPS3801 and TPS3809 supply voltage supervisor (SVS) families of devices. The report gives a general introduction to reset generators followed by an overview of the technical parameters and the special features of the TPS380x. Each feature is discussed separately. Measurements make it easy to understand SVS principles of operation. Typical applications that inc
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > Other C5000 DSP
TMS320LC542PGE150, TMS320LC542PGE1 50
На английском языке: Datasheet Texas Instruments TMS320LC542PGE1-50
