Линейка продуктов KEEN SIDE
Datasheet Texas Instruments UC2854NG4 — Даташит
СерияUC2854
МодельUC2854NG4
Пререгулятор высокого коэффициента мощности 16-PDIP от -40 до 85
UCx854 High-Power Factor Preregulator datasheet
PDF, 949 Кб, Версия: A, Файл опубликован: 16 дек 2016
Pin16
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаUC2854N
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Control MethodCCM
Device TypeSingle-phase PFC
Operating Supply Current10 мА
Operating Supply(Max)30 В
Package GroupPDIP
Peak Output Sink Current Gate Drive1 A
Peak Output Source Current Gate Drive-1 A
Practical Operating Frequency(Max)0.2 МГц
Special FeaturesAverage Current Mode,Enable
Startup Current1.5 мА
UVLO Thresholds On/Off16/10 В
  • U-134 UC3854 Controlled Power Factor Correction Circuit Design
    PDF, 346 Кб, Файл опубликован: 5 сен 1999
    The UC1854 provides active power factor correction for power systems that otherwise would draw non-sinusoidal current from sinusoidal power lines. This device implements all the control functions necessary to build a power supply capable of optimally using available power-line current while minimizing line-current distortion. This application note describes the concepts and design of a boost prere
  • DN-39E Optimizing Performance in UC3854 Power Factor Correction Applications
    PDF, 277 Кб, Файл опубликован: 5 сен 1999
    The performance of the UC3854 Power-Factor Correction IC in the 250W application example has been evaluated using a precision PFC/THD instrument. The result was a power factor of 0.999 and Total Harmonic Distortion (THD) of 3.81%, measured to the 50th line frequency harmonic at nominal line and full load. Users should get similar results at these conditions. as well as over most line and load rang
  • DN-41 Extend Current Transformer Range
    PDF, 37 Кб, Файл опубликован: 5 сен 1999
    The problems with self reset of current transformers for unipolar pulse applications can be overcome with simple forced-reset techniques derived from magnetic amplifiers. Duty factors above 90% are achievable with these techniques. This design note describes a circuit configured for forced reset and a configuration that generates a negative voltage from the current transformer.
  • AC Requirements for Power Factor Correction Circuits
    PDF, 29 Кб, Файл опубликован: 28 мар 2002
    This technical brief identifies the recommended range of IAC for each of the devices within the UCC3854 family of PFC controllers.
  • Accurate PWM Duty Cycle Clamp
    PDF, 58 Кб, Файл опубликован: 25 янв 2002
    Power supply applications using current sense transformers require a duty cycle clamp on the pulse width modulator (PWM) to ensure transformer reset. Not all PWMs come with a duty cycle clamp presenting a problem for the power supply designer. This application note shows how to implement a duty cycle clamp by using a simple delay circuit.
Серия: UC2854 (6)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
На английском языке: Datasheet Texas Instruments UC2854NG4
