Datasheet Texas Instruments UC1525AL — Даташит
СерияUC1525A
МодельUC1525AL
Регулирующие широтно-импульсные модуляторы 20-LCCC от -55 до 125
UCx52xA Regulating Pulse Width Modulators datasheet
PDF, 965 Кб, Версия: D, Файл опубликован: 27 июл 2017
Pin20
Package TypeFK
Industry STD TermLCCC
JEDEC CodeS-CQCC-N
Package QTY1
МаркировкаUC1525AL
Width (мм)8.89
Length (мм)8.89
Thickness (мм)1.83
Max Height (мм)2.03
Control MethodVoltage
Duty Cycle(Max)50 %
Frequency(Max)500 kHz
Frequency(Min)0.1 kHz
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
Special FeaturesError Amplifier,Soft Start,Synchronization Pin,Multi-topology
TopologyBoost,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off7/6.8 В
Vin(Max)35 В
Vin(Min)8 В
RoHSSee ti.com
  • DN-62 Switching Power Supply Topology Voltage Mode vs. Current Mode
    PDF, 66 Кб, Файл опубликован: 5 сен 1999
    This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments UC1525AL
