Помощь в переводе проектов на ПЛИС азиатских брендов
Datasheet Texas Instruments SM320C80GFM50 — Даташит
СерияSM320C80
МодельSM320C80GFM50
Процессоры цифровых сигналов 305-CPGA от -55 до 125
SMJ320C80 Digital Signal Processor datasheet
PDF, 3.4 Мб, Версия: B, Файл опубликован: 30 июн 2002
Pin305
Package TypeGF
Industry STD TermCPGA
JEDEC CodeS-CPGA-P
Package QTY1
CarrierJEDEC TRAY (5+1)
МаркировкаSM320C80GFM50
Width (мм)47.25
Length (мм)47.25
Thickness (мм)3.3
Max Height (мм)5.59
Cycle Time20 нс
DMA1 Ch
Data / Program Memory Space2.4G Words
Тактовая частота50 МГц
MIPS60
MOPS120
Package GroupCPGA
Pin/Package305CPGA, 320CFP
RatingMilitary
RoHSSee ti.com
  • Modified Goertzel Algorithm in DTMF Detection Using the TMS320C80 DSP
    PDF, 101 Кб, Файл опубликован: 1 июн 1996
    This document presents a modified Goertzel algorithm for DTMF tone detection on a TMS320C80 ('C80) 32-bit multiprocessor digital signal processor (DSP). The algorithm detects the incoming frequency with an offset range plus or minus 1.5%. For this application, a basic implementation is provided, but additional testing is required to make this detection algorithm complete. The appendix provides the
  • Acoustic Echo Cancellation Algorithms and Implementation on the TMS320C80
    PDF, 223 Кб, Файл опубликован: 1 май 1996
    Acoustic echo cancellation on the TMS320C8x multiprocessor digital signal processor (DSP) offers high performance and flexibility to meet varying user needs. This document describes the implementation of an integrated N-tap digital acoustic echo canceller on the TMS320C8x parallel processor (PP). A brief discussion of a generic echo cancellation algorithm is provided. A 512-tap (64-ms span) echo
  • TMS320C8x System-Level Synopsis (Rev. B)
    PDF, 516 Кб, Версия: B, Файл опубликован: 1 сен 1995
    The TMS320C8x is Texas Instruments? first generation of single-chipmultiprocessor digital signal processor (DSP) devices. Asingle ?C8x contains up to five powerful, fully programmable pro-cessors:a master processor (MP) and up to four parallel proces-sors(PPs). The MP is a 32-bit RISC (reduced instruction setcomputer) processor with an integral, high-performanceIEEE-754 floating-point
Серия: SM320C80 (2)
  • Semiconductors > Processors > Digital Signal Processors > Other High Reliability DSPs
На английском языке: Datasheet Texas Instruments SM320C80GFM50
