Datasheet Texas Instruments SN74LVC139AGQNR — Даташит
СерияSN74LVC139A
МодельSN74LVC139AGQNR
SN74LVC139A datasheet
PDF, 1.1 Мб, Версия: O, Файл опубликован: 2 окт 2003
Pin20
Package TypeGQN
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeR-PBGA-N
МаркировкаLC139A
Width (мм)3
Length (мм)4
Thickness (мм).75
Max Height (мм)1
Рекомендуемая замена
ReplacementSN74LVC139AZQNR
Replacement CodeP
Approx. Price (US$)0.12 | 1ku
Bits(#)4
Channels(#)2
Configuration2:4
F @ Nom Voltage(Max)(Mhz)100
FunctionDecoder/Demultiplexer
ICC @ Nom Voltage(Max)(mA)0.01
Тип входаTLL/CMOS
Operating Temperature Range(C)-40 to 85
Output Drive (IOL/IOH)(Max)(mA)24/-24
Тип выходаCMOS
Package GroupBGA MICROSTAR JUNIOR
SO
SOIC
SSOP
TSSOP
TVSOP
VQFN
Package Size: mm2:W x L (PKG)20BGA MICROSTAR JUNIOR: 12 mm2: 3 x 4(BGA MICROSTAR JUNIOR)
16VQFN: 14 mm2: 3.5 x 4(VQFN)
16TVSOP: 23 mm2: 6.4 x 3.6(TVSOP)
16TSSOP: 32 mm2: 6.4 x 5(TSSOP)
16SSOP: 48 mm2: 7.8 x 6.2(SSOP)
16SOIC: 59 mm2: 6 x 9.9(SOIC)
16SO: 80 mm2: 7.8 x 10.2(SO)
Schmitt TriggerNo
Technology FamilyLVC
ТипStandard
VCC(Max)(V)3.6
VCC(Min)(V)1.65
Voltage(Nom)(V)1.8
2.5
2.7
3.3
tpd @ Nom Voltage(Max)(ns)20.6
9.3
7.3
6.2
RoHSНе совместим
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Specialty Logic > Decoder/Encoder/Multiplexer
На английском языке: Datasheet Texas Instruments SN74LVC139AGQNR
