Оптопары и оптореле Megawin
Datasheet Texas Instruments MSP430I2030TPWR — Даташит
СерияMSP430I2030
МодельMSP430I2030TPWR
16-битный микроконтроллер смешанных сигналов 28-TSSOP от -40 до 105
MSP430i204x, MSP430i203x, MSP430i202x Mixed-Signal Microcontrollers datasheet
PDF, 1.4 Мб, Файл опубликован: 31 авг 2014
Pin28
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаI2030T
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
ADCSigmaDelta24 - 3ch
AESN/A
Active Power274.658 uA/MHz
Additional FeaturesWatchdog,Temp Sensor,Brown Out Reset,IrDA
BSLNone
CPUMSP430
Featuredi2
Тактовая частота16 МГц
GPIO Pins16
I2C1
Max VCC3.6
Min VCC2.2
Multiplier16x16
Non-volatile Memory16 KB
Package GroupTSSOP
Package Size: mm2:W x L28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) PKG
RAM1 KB
SPI2
Special I/ON/A
Standby Power210 LPM3-uA
Timers - 16-bit2
UART1
Wakeup Time1 us
  • Development Kits: MSP-TS430RHB32A
    MSP-TS430RHB32A - 32-pin Target Development Board for MSP430i2x MCUs
  • Evaluation Modules & Boards: EVM430-I2040S
    MSP430i2040 Sub metering EVM
  • Evaluation Modules & Boards: MSP-FET430U32A
    32-pin Target Development Board and MSP-FET Programmer Bundle for MSP430i2x MCUs
  • Implementation of One- or Two-Phase Electronic Watt-Hour Meter Using MSP430i20xx (Rev. A)
    PDF, 4.0 Мб, Версия: A, Файл опубликован: 11 сен 2014
    This application report describes the implementation of a low-cost one- or two-phase electronic electricity meter using the Texas Instruments MSP430i20xx metering processor. This application report includes the necessary information with regard to metrology software and hardware procedures for this single-chip implementation.Source code and other collateral described in this document can be down
  • Programming With the MSP430AFE2xx Family and the MSP430i20xx Family
    PDF, 89 Кб, Файл опубликован: 10 авг 2014
    This application report enables the easy incorporation of the MSP430AFE2xx family of MCUs, featuring the SD24_A module, as well as the MSP430i20xx family of MCUs, which features the SD24 module, into new designs. It covers programming, system, and peripheral considerations when creating firmware. The intent is to highlight a few key differences between the two families and how to incorporate each
  • Migrating From MSP430 F2xx and G2xx Families to MSP430 FR4xx and FR2xx Family (Rev. E)
    PDF, 237 Кб, Версия: E, Файл опубликован: 4 май 2018
    This application report helps to ease the migration from MSP430F2xx flash-based MCUs to the MSP430FR4xx and MSP430FR2xx family of FRAM-based MCUs. It discusses programming system hardware core architecture and peripheral considerations. The intent is to highlight key differences between the two families. For more information on the use of the MSP430FR4xx and MSP430FR2xx devices see the MSP430
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430G2x/i2x
На английском языке: Datasheet Texas Instruments MSP430I2030TPWR
