Клеммники KEEN SIDE
Datasheet Texas Instruments LM25574QMTX/NOPB — Даташит
СерияLM25574-Q1
МодельLM25574QMTX/NOPB
SIMPLE SWITCHERВ® 42V, 0.5A Step-Down Switching Regulator 16-TSSOP -40 to 125
LM25574/LM25574Q SIMPLE SWITCHERВ® 42V, 0.5A Step-Down Switching Regulator (Rev. G)
PDF, 967 Кб, Версия: G, Файл опубликован: 3 апр 2013
IC REG BUCK ADJ 500MA 16TSSOP. Buck Switching Regulator IC Positive Adjustable 1.225V 1 Output 500mA 16-TSSOP (0.173', 4.40mm Width). PMIC...
LM25574QMTX/NOPB
57 ₽
LM25574QMTX/NOPB
193 ₽
Hi-Tech Circuit Group
LM25574QMTX/NOPB
LM25574QMTX/NOPB
Pin1616
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаQMTL25574
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Approx. Price (US$)1.60 | 1ku
Control ModeCurrent Mode
Duty Cycle(Max)(%)95
Iout(Max)(A)0.5
Iq(Typ)(mA)1
Operating Temperature Range(C)-40 to 125
Package GroupTSSOP
RatingAutomotive
Regulated Outputs(#)1
Special FeaturesFrequency Synchronization
Switching Frequency(Max)(kHz)1000
Switching Frequency(Min)(kHz)50
ТипConverter
Vin(Max)(V)42
Vin(Min)(V)6
Vout(Max)(V)40
Vout(Min)(V)1.23
  • Evaluation Modules & Boards: LM25574EVAL
    Evaluation Board for LM25574, 42V, 0.5A Step-Down Switching Regulator
  • Understanding and Applying Current-Mode Control Theory
    PDF, 409 Кб, Файл опубликован: 19 авг 2007
  • AN-1997 Error Amplifier Limitations in High-Performance Regulator Applications (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 6 май 2013
    The development of realistic predictions to assist the power supply engineer during the control loop design process is facilitated in this application report by appropriate small-signal and bode plot analysis, the validity of which is verified through simulation results.
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
  • Quick Start Guide for a 0.5 Amp Buck Regulator Using The LM5574 and LM25574 (Rev. B)
    PDF, 61 Кб, Версия: B, Файл опубликован: 23 апр 2013
    The LM5574 and LM25574 switching regulators feature all of the functions necessary to implement anefficient high voltage buck regulator using a minimum of external components. These easy to useregulators include either a 42V (LM25574) or a 75V (LM5574) N-Channel buck switch with an outputcurrent capability of 0.5 Amps. The operating frequency is programmable from 50kHz up to 1MHz.Protectio
  • Overcoming Challenges in Designing Step-Dwn Reg Apps w/40V Input Voltage
    PDF, 538 Кб, Файл опубликован: 30 мар 2007
Серия: LM25574-Q1 (2)
На английском языке: Datasheet Texas Instruments LM25574QMTX/NOPB
