Datasheet Texas Instruments AM26LS31CDBRE4 — Даташит
СерияAM26LS31
МодельAM26LS31CDBRE4
Четырехфазный дифференциальный драйвер линии 16-SSOP от 0 до 70
AM26LS31x Quadruple Differential Line Driver datasheet
PDF, 1.3 Мб, Версия: K, Файл опубликован: 28 июл 2016
Pin16
Package TypeDB
Industry STD TermSSOP
Package QTY2000
МаркировкаSA31C
Width (мм)5.3
Length (мм)6.2
Thickness (мм)1.95
Max Height (мм)2
ICC(Max)80 мА
Package GroupSSOP
Signaling Rate10 Mbps
Supply Voltage(s)5 В
  • Wave Solder Exposure of SMT Packages
    PDF, 206 Кб, Файл опубликован: 9 сен 2008
    It is common practice to attach surface mount components to the underside of a printed circuit board (PCB) by processing the PCB through a wave soldering operation after gluing the components to the PCB. This paper ummarizes results of several tests performed to understand the performance of surface mount components when exposed to the conditions outlined in JESD22A111.
На английском языке: Datasheet Texas Instruments AM26LS31CDBRE4
