Datasheet Texas Instruments LM43600PWPR — Даташит
СерияLM43600
МодельLM43600PWPR
Синхронный понижающий преобразователь напряжения 3,5–36 В, 500 мА 16-HTSSOP от –40 до 125
LM43600 3.5-V to 36-V, 0.5-A Synchronous Step-Down Voltage Converter datasheet
PDF, 2.8 Мб, Версия: B, Файл опубликован: 4 сен 2017
Pin16
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаLM43600
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Control ModeCurrent Mode
Duty Cycle(Max)99 %
Iout(Max)0.5 A
Iq(Typ)0.033 мА
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Light Load Efficiency,Power Good,Synchronous Rectification,Tracking
Switching Frequency(Max)2200 kHz
Switching Frequency(Min)200 kHz
ТипConverter
Vin(Max)36 В
Vin(Min)3.5 В
Vout(Max)28 В
Vout(Min)1 В
  • Evaluation Modules & Boards: LM43600PWPEVM
    LM43600PWP Synchronous Step-Down Converter Evaluation Module
  • Thermal Design Made Simple With LM43603 and LM46002
    PDF, 535 Кб, Файл опубликован: 15 сен 2014
    This Application Report will walk through the thermal design of power supplies using the LM43603 and LM46002.In the process we will cover common tips and approximations to speed up your design.
  • Inverting Applications Made SIMPLE With LM4600x and LM4360x (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 20 фев 2015
    Weoftenrequirepowersourceswithnegativeoutputvoltages.Therearemanydifferentwaystoproduceanegativeoutputvoltagefromapositiveinputvoltage.Oneoptionisapolarity-invertingbuck-boostconverter.Theadvantagesofthistopologyarethatitrequireslowcomponentcountandthatitcanbebuiltwithstandardhigh-sideregulato
  • Compensation Made SIMPLE With LM4360x, LM4600x
    PDF, 457 Кб, Файл опубликован: 29 июл 2014
    Compensating a DC-DC buck converter is challenging if the designer is not familiar with the loop control theory. To achieve a stable design under all corner and adverse conditions, the user must properly compensate the regulator. While DC-DC converters with external compensation provide flexibility, they increase complexity. The LM43600/1/2/3 and LM46000/1/2 are a family of Wide VIN, fully-synchro
  • AN-1533 Overvoltage Protection Circuit for Automotive Load Dump (Rev. B)
    PDF, 83 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application report discusses an over voltage protection circuit for automotive load dump.
  • Understanding and Applying Current-Mode Control Theory
    PDF, 409 Кб, Файл опубликован: 19 авг 2007
  • AN-1997 Error Amplifier Limitations in High-Performance Regulator Applications (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 6 май 2013
    The development of realistic predictions to assist the power supply engineer during the control loop design process is facilitated in this application report by appropriate small-signal and bode plot analysis, the validity of which is verified through simulation results.
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
Серия: LM43600 (3)
На английском языке: Datasheet Texas Instruments LM43600PWPR
