Datasheet Texas Instruments SN74LVC1GX04DRLR — Даташит
СерияSN74LVC1GX04
МодельSN74LVC1GX04DRLR
Драйвер кварцевого генератора 6-SOT-5X3 от -40 до 125
SN74LVC1GX04 Crystal Oscillator Driver datasheet
PDF, 1.0 Мб, Версия: D, Файл опубликован: 29 окт 2015
Pin66
Package TypeDRLDRL
Industry STD TermSOT-5X3SOT-5X3
JEDEC CodeR-PDSO-NR-PDSO-N
Package QTY40004000
CarrierLARGE T&RLARGE T&R
МаркировкаD2RD27
Width (мм)1.21.2
Length (мм)1.61.6
Thickness (мм).55.55
Pitch (мм).5.5
Max Height (мм).6.6
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeOSCILLATOR INVERTER/BUFFER
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupSOT-5X3
Package Size: mm2:W x L6SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) PKG
Schmitt TriggerNo
Special FeaturesIoff,down translation to Vcc,low power,Unbuffered output
Sub-FamilyInverting Buffer/Driver
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)7,4,3.7,7 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1GX04DRLR
