Datasheet ТI SN74LVC07APWLE — Даташит
| Серия | SN74LVC07A |
| Модель | SN74LVC07APWLE |
Шестнадцатеричный буфер/драйвер с выходами с открытым стоком 14-TSSOP от -40 до 85
SN74LVC07A Hex Buffer and Driver With Open-Drain Outputs datasheet
PDF, 1.2 Мб, Версия: W, Файл опубликован: 13 ноя 2015
- LVC07A: Applications Of An Open-Drain Hex Buffer And Discussion Of Char ResultsPDF, 51 Кб, Файл опубликован: 8 апр 1999
The Texas Instruments (TI) LVC07A hex buffer, with open-drain outputs, and its inverting counterpart, LVC06A, operate in the 1.65-V to 3.6-V VCC range, but can accept input voltages up to 5.5 V. Laboratory results show superior propagation times versus competitors, natural Ioff protection, and output-breakdown capability versus a competitor. Applications of the LVC07A and LVC06A include bus-conte - LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC07A (26)
- SN74LVC07AD SN74LVC07ADBR SN74LVC07ADBRG4 SN74LVC07ADE4 SN74LVC07ADG4 SN74LVC07ADGVR SN74LVC07ADR SN74LVC07ADRE4 SN74LVC07ADRG3 SN74LVC07ADRG4 SN74LVC07ADT SN74LVC07ADTG4 SN74LVC07ANSR SN74LVC07APW SN74LVC07APWE4 SN74LVC07APWG4 SN74LVC07APWLE SN74LVC07APWR SN74LVC07APWRE4 SN74LVC07APWRG3 SN74LVC07APWRG4 SN74LVC07APWT SN74LVC07APWTE4 SN74LVC07APWTG4 SN74LVC07ARGYR SN74LVC07ARGYRG4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
