Datasheet Texas Instruments LM5161PWP — Даташит
СерияLM5161
МодельLM5161PWP
Синхронный понижающий/понижающий преобразователь с широким входом, 4,5–100 В, 1 А, 14-HTSSOP от -40 до 125
LM5161 Wide Input 100-V, 1-A Synchronous Buck/Fly-Buckв„ў Converter datasheet
PDF, 2.1 Мб, Версия: A, Файл опубликован: 23 авг 2016
Pin14
Package TypePWP
Industry STD TermHTSSOP
Package QTY94
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Approx. Price (US$)1.80 | 1ku
Control ModeCOT with emulated ripple
Constant on-time (COT)
Duty Cycle(Max)(%)92
Iout(Max)(A)1
Iq(Typ)(mA)2.3
Operating Temperature Range(C)-40 to 125
Package GroupHTSSOP
Regulated Outputs(#)1
Special FeaturesEnable
Light Load Efficiency
Synchronous Rectification
UVLO Adjustable
Switching Frequency(Max)(kHz)1000
Switching Frequency(Min)(kHz)50
ТипConverter
Vin(Max)(V)100
Vin(Min)(V)4.5
Vout(Max)(V)92
Vout(Min)(V)2
RoHSНе совместим
  • Evaluation Modules & Boards: LM5161PWPBKEVM
    LM5161 Wide VIN Synchronous Buck Converter Constant On-Time Evaluation Module
  • Evaluation Modules & Boards: LM5161PWPFBKEVM
    LM5161 Wide VIN Fly-Buck Evaluation Module
  • Is Your IGBT Gate-Driver Power Supply Optimized
    PDF, 115 Кб, Файл опубликован: 12 мар 2015
    Insulated Gate Bipolar Transistors (IGBTs) are used in high current three-phase AC motors. This application report discusses the theory and requirements of gate-drive power supply for IGBTs. It also discusses the isolation requirements and calculation of correct amount of IGBT drive power.
  • AN-2292 Designing an Isolated Buck (Fly-Buck) Converter (Rev. C)
    PDF, 870 Кб, Версия: C, Файл опубликован: 17 дек 2014
    In many applications, one or more low-cost, simple to use, isolated power supplies working from input voltages up to 100 V are needed. Traditional solutions use flyback converters to generate this bias supply. Flyback designs typically utilize asymmetric transformers turns ratios for primary and secondary power windings, with an optocoupler and reference, or an auxiliary winding for feedback regul
  • Fly-Buck(TM) converter provides EMC and isolation in PLC applications
    PDF, 201 Кб, Файл опубликован: 29 янв 2015
Серия: LM5161 (3)
На английском языке: Datasheet Texas Instruments LM5161PWP
